Probe_Basic Not Writing Parameter Variables
- Sbvr4
19 Jul 2025 14:10 #332015
by Sbvr4
Probe_Basic Not Writing Parameter Variables was created by Sbvr4
Good Morning,
I've installed Probe Basic and continue to have an issue with parameters not being written to the .var file. Anytime a value is updated via Probe_basic ui, a "File not Open" error shows and no changes are made to the .var file. Parameters entered via Gcodes work fine. For instance, SET TOOL TOUCH OFF POS generates "File Not Open" error, but MDI g30.1 works fine. The sim version works fine.
Terminal shows: emctask.cc 68: interp_error
I am running:
Debian 12 Bookworm
LCNC v2.10
Current version of Probe_basic and QtPyVCP
installed sable APT version
Any help would be greatly appreciated.
Thank you,
Sean
I am running:
Debian 12 Bookworm
LCNC v2.10
Thank you,
Sean
- Lcvette
- Thank you received: 784
20 Jul 2025 13:43 #332057
by Lcvette
Replied by Lcvette on topic Probe_Basic Not Writing Parameter Variables
Does the sim work? If so its a configuration problem.
Moderators: KCJ, Lcvette
Time to create page: 0.093 seconds
