Knurling w/ threading tool using G33 - Emco 120P
14 Sep 2015 00:14 #62521
by tome
Knurling w/ threading tool using G33 - Emco 120P was created by tome
Here is a video of our G33 knurling routine running. Pretty cool. I’m sure we aren’t the first to do this, but since I haven’t seen it before I will pretend like it BTW, this knurl is only about 5 thou deep, deeper ones will follow.
Here is the code:
G8
G53 G0 X0
G53 G0 Z0
M6 T3 G43
#<workpieceDia> = 0.700
#<workpieceRad> = [#<workpieceDia>/2]
#<safeXOffset> = 0.025
#<safeX> = [#<workpieceRad> + #<safeXOffset>]
#<knurlStartZ> = 0.000
#<knurlLen> = 0.25
#<knurlLeadIn> = 0.010
#<knurlDepth> = 0.002
#<knurlPerDia> = 28
#<knurlAngle> = 30
#<knurlEndZ> = [#<knurlStartZ> - #<knurlLen>]
#<rpm> = 100
#<pi> = 3.142
; The surface is the circumference of the workpiece
#<workSurface> = [#<pi> * #<workpieceDia>]
; Given a knurl angle, calculate Z feed given <workSurface>
#<feedPerRev> = [TAN[#<knurlAngle>] * #<workSurface>]
#<feedPerMin> = [#<feedPerRev> * #<rpm>]
(debug, feed per revolution: #<feedPerRev>; per min: #<feedPerMin>)
; thread _width_ is equal to distance traveled in one rev, i.e. <feedPerRev>
#<threadWidth> = #<feedPerRev>
; Thus, TPI will be 1/<threadWidth>
#<tpi> = [1/#<threadWidth>]
; To do a n-start thread, we need to start each thread
; <threadWidth>/n further back (Z+) than the prior thread
#<nStartZOffset> = [#<threadWidth>/#<knurlPerDia>]
M3 S#<rpm>
#100 = #<knurlPerDia>
#110 = [[#<knurlPerDia> * #<nStartZOffset>] + #<knurlStartZ> + #<knurlLeadIn>]
(debug, knurl lead in: #110)
G0 Z#110
G0 X[#<workpieceRad> - #<knurlDepth>]
O100 WHILE [#100 GT 0]
(debug, start Z: #110; feed: #<feedPerRev>)
(calculate the lead in for the knurl AFTER this one)
#105 = #110
#110 = [#110 - #<nStartZOffset>]
;G33 Z#110 K#<feedPerRev>
;G1 Z#<knurlEndZ> F#<feedPerMin>
;G1 Z#105 F#<feedPerMin>
G33 Z#<knurlEndZ> K#<feedPerRev>
G33 Z#105 K#<feedPerRev>
;G0 X#<safeX>
G0 Z#110
;G0 X[#<workpieceRad> - #<knurlDepth>]
#100 = [#100 - 1]
O100 ENDWHILE
Here is the code:
G8
G53 G0 X0
G53 G0 Z0
M6 T3 G43
#<knurlLen> = 0.25
#<knurlPerDia> = 28
#<knurlAngle> = 30
#<rpm> = 100
#<pi> = 3.142
M3 S#<rpm>
G0 Z#110
#105 = #110
;G0 X#<safeX>
G0 Z#110
#100 = [#100 - 1]
O100 ENDWHILE
- Dinuka_Shehan
- Thank you received: 26
18 Oct 2019 21:43 #148228
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Knurling w/ threading tool using G33 - Emco 120P
Can you post the actual code without tags
18 Oct 2019 22:53 #148231
Replied by cmorley on topic Knurling w/ threading tool using G33 - Emco 120P
If you mean 'tags' like this : #<workpieceDia>
Those are variables and make it easy to change the parameters of the program.
They are ugly but necessary
Chris
Chris
- Thank you received: 5874
18 Oct 2019 23:24 #148236
Replied by tommylight on topic Knurling w/ threading tool using G33 - Emco 120P
# is not a tag, it is just miss used as one, it is a numbered parameter.
- Dinuka_Shehan
21 Oct 2019 06:28 - 21 Oct 2019 06:30 #148443
by Dinuka_Shehan
Thanks for information
How can I post this code with custom values.
If i want to cut 25 tpi in 1inch stock.
If a metric based machine work with this?
Any ideas?
Any ideas?
Last edit: 21 Oct 2019 06:30 by Dinuka_Shehan.
Time to create page: 0.108 seconds
