Rods "Spaceship" Scratch built Plasma Cutter build
04 Apr 2017 19:52 #90882
Replied by rodw on topic Rods "Spaceship" Scratch built Plasma Cutter build
Believe me, its coming by the end of the week!I do not see any beer there?
05 Apr 2017 02:16 #90904
Well, I ran into t bit of a problem becasue I wanted to use Norberts updates to Gmocappy in Master and Dewey's external offset code in a different branch.
I managed to merge the two together with these codes:
The other problem is that the original code I had to show the up and down direction via LEDs in the GUI, the pin I used no longer exists. So I wrote a HAL component to do this for me. I have to say I am enjoying writing components to fix things, It does not take long, puts me back in the familiar C language and they only take seconds to compile and install.
I've attached the .comp and here is an example based on the gmocappy plasma signals.hal file
git checkout master
git pull
git checkout dgarr/external_offsets
git pull
git rebase -i master
git checkout master
git merge dgarr/external_offsets
loadrt showzdir names=zdir
addf showzdir servo-thread
net z-position axis.z.pos-cmd => zdir.zpos-cmd
net z-moves-up zdir.z_moving-up => signals.led-move-up
net z-moves-up zdir.z_moving-down => signals.led-move-down
08 Apr 2017 06:56 #91031
- Thank you received: 5872
08 Apr 2017 09:13 #91034
Replied by tommylight on topic Rods "Spaceship" Scratch built Plasma Cutter build
I would like to quote Mythbasters at this point " there's your problem " !
08 Apr 2017 10:07 #91037
Tommy, I had no idea you were so observant
So now I think I need to come up with an alternative to the circuit board.....
09 Apr 2017 09:14 #91078
Replied by andypugh on topic Rods "Spaceship" Scratch built Plasma Cutter build
Reinforce the circuit board?
09 Apr 2017 10:07 #91081
Andy, I remade it today and reworked the way it mounts up as the sockets for the steppers caused it to bend.
.And a quick bit of milling
And it fits up quite nicely with a couple of drilled and tapped holes.
And all back together and powered up
But it did not fix my problem. I was beginning to suspect Gmocappy so I rolled back to Axis but I can't get it out of estop. I did post a separate thread but if you have nay ideas on where to go as I am stiumped.
12 Apr 2017 10:01 #91230
lt's been a while but Lee finally had time to weld the rest of the table for me.
You can see why I asked him to weld up this for me
I certainly would not be showcasing one of my pathetic beads.
And by the end of the night, I had a table!
I just hope we welded the drag chain support on the right side!
We just have to sort out the material support slats. I have a feeling my original design is not going to be sturdy enough but right now, that is the least of my problems.
13 Apr 2017 09:22 #91287
Well, I got some of the table assembled today and the gantry ends are in place
I am happy with the clearance between the gantry ends and the table.
Hopefully, it will help keep the rails clean tucked so far back.
Its kinda funny, when I was looking at the gantry ends, they looked to long but now they are assembled, they look correct and in proportion.
I am hoping I will be able to get a bit more together over the Easter break.
13 Apr 2017 10:20 #91290
Looking nice bro.
Time to create page: 0.205 seconds
