Controlling temperature of reprap extruder hot-end
23 Sep 2011 11:40 #13383
by fma
Replied by fma on topic Re:Controlling temperature of reprap extruder hot-end
Mmm, such log-amplifing circuits don't look easy to build! I think a software-based linearizer is much easier...
23 Sep 2011 11:41 #13384
by Rick G
Replied by Rick G on topic Re:Controlling temperature of reprap extruder hot-end
Try looking at Analog Devices AD594 or AD595
Also their Application Note AN-369 on the circuit.
Rick G
Rick G
23 Sep 2011 11:43 #13385
by Rick G
23 Sep 2011 11:46 #13387
by fma
This chip is for thermocouples, not for thermistors...
23 Sep 2011 12:15 #13388
Replied by andypugh on topic Re:Controlling temperature of reprap extruder hot-end
fma wrote:
(I have written a few in Excel for my job, I write engine maps)
Perhaps I will look into it in more detail this weekend.
I keep toying with the idea of writing a 1D / 2D interpolator for HAL.BTW, is there a way to linearize an signal?...
If not, I guess I will have to write this component?
23 Sep 2011 14:34 #13395
by Rick G
Yep, thermocouples small, rugged, inexpensive. You can build the circuit to be very accurate in the temp range you want to work.
But there maybe a software solution also.
Rick G
Rick G
23 Sep 2011 19:13 #13406
by fma
@andypugh,
that would be nice!
@Rick,
A friend will give me a platiniul sensor, wich is even less expensive, and linear enough for my needs. I will just have to drive the NE55.
that would be nice!
@Rick,
23 Sep 2011 19:41 #13408
by cncbasher
Replied by cncbasher on topic Re:Controlling temperature of reprap extruder hot-end
a MAX6675 is a much better thermocouple solution ( single chip & 2 cap ) , and theirs plenty of circuits and code available
23 Sep 2011 22:04 #13414
by fma
But I would like to avoid using an external ยต-controller, and instead use EMC.
24 Sep 2011 18:47 #13426
I had all sorts of ideas, but in the end ended up with something very simple indeed.
Should actually do all that you need.
The actual values you need to use would probably be most easily obtained using Excel or Open Office, using a curve-fit on a graph of calibration data.
As you will have an (unknown to me) transfer function between the value in HAL and the resistance of the NTC I can't suggest any numbers at the moment, but if you have any calibration data I can show you what the HAL snippet would need to look like.
component polynomial "Applies an up-to-7 order polynomial transformation";
pin in float in "input value";
pin out float out "output value";
pin in float coeff-#[8] "polynomial coefficients";
function _;
license "GPL";
author "Andy Pugh";
include <rtapi_math.h>;
FUNCTION(_) {
int i;
out = 0;
for (i = 0 ; i < 8 ; i++){
out += coeff(i) * pow(in, i);
Time to create page: 0.233 seconds
