5 axis milling machine?
01 Dec 2011 02:24 #15243
by KobeYang
5 axis milling machine? was created by KobeYang
Hi all,I try to make a 5 axis milling machine with tilting head fixed in y axis,I read some paper which says RTCP(Rotation Tool Centre Point ),Doesn't EMC have this function?If has,how to use it ?if not,how do I intergrate my machine with EMC? Help,thanks.
01 Dec 2011 13:04 #15249
by BigJohnT
Replied by BigJohnT on topic Re:5 axis milling machine?
There is a 5 axis sample configuration you can try out. It may not match your machine exactly but you could change it to match.
02 Dec 2011 03:21 #15270
by KobeYang
Replied by KobeYang on topic Re:5 axis milling machine?
where can i find it ?the release version? If yes,I want to know why we need config the W-axis?
02 Dec 2011 10:11 #15275
Replied by andypugh on topic Re:5 axis milling machine?
KobeYang wrote:
I think that in the sample 5axiskins config the W-axis is used for tool-length compensation.
I also seem to recall that you can drill angled holes using coordinated, moves in the W axis.
I think this machine is doing W-axis moves around 2:28
Time to create page: 0.069 seconds
