Need front panel buttons for emergency commands.
30 Jan 2010 15:58 #1700
by greeder88
Need front panel buttons for emergency commands. was created by greeder88
I need to have hard buttons on the front panel to do PROGRAM HOLD and PROGRAM START. Does anyone know the Hal file lines that will work for these? How about QUILL UP too?
30 Jan 2010 16:52 #1702
by acemi
Replied by acemi on topic Re:Need front panel buttons for emergency commands.
www.linuxcnc.org/docs/devel/html/gui_halui.html
www.linuxcnc.org/docs/devel/html/gui_halui.html#r1_2_15
You need to link an input pin to the halui pin.
02 Dec 2011 20:32 #15296
by RayJr
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Replied by RayJr on topic Re:Need front panel buttons for emergency commands.
The links in the previous post seem to be bad.
Ray
Ray
Albert Einstein
02 Dec 2011 22:58 #15301
Replied by andypugh on topic Re:Need front panel buttons for emergency commands.
03 Dec 2011 01:10 #15309
by RayJr
Albert Einstein
That works!
Thank You!
Please forgive my ignorance, but in the first line on that page:
"Halui is a HAL based user interface for EMC, it connects HAL pins to NML commands."
Waht does "NML" stand for?
Ray
Thank You!
Ray
Albert Einstein
03 Dec 2011 02:41 #15314
RayJr wrote:
Now you mention it, i have no idea.
It doesn't matter, in fact I am not entirely sure it is still true.
Lets say "Halui is an interface that lets you see inside EMC2, and also change values"
03 Dec 2011 04:56 #15316
by bjames28
Replied by bjames28 on topic Re:Need front panel buttons for emergency commands.
Hi RayJr,
NML file is used for defining the communication within EMC. Usually it's done inside one PC, but you can forward GUI to another PC over the Ethernet.
Or for example when you have a pendant with LCD to display messages on it.
dynomotion.com/Help/GCodeScreen/EMC_Handbook/node110.html
www.wallacecompany.com/machine_shop/EMC2/remote_notes.html
James28
James28
Time to create page: 0.073 seconds
