Remote control setup
10 Feb 2012 08:48 #17541 by tommy
Remote control setup was created by tommy
What is left from mach3 "histrory" not used on my machine is simple remote control on usb.
As I am not very experienced in Linux, so lets say for a start, is there a way to map keystrokes (arrow keys) and feed rate from this device?
Control looks like this:
10 Feb 2012 10:42 - 10 Feb 2012 10:49 #17543 by ArcEye
Replied by ArcEye on topic Re:Remote control setup
Hi
Have a look at the main wiki page
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_X11_Joystick_Driver
and several other pages on the same subject under the heading Adding external controls
especially this one wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...ove_Your_CNC_Machine
The principles of allocating keystrokes to USB joystick buttons etc are the same
John has plenty of knowledge re this one when you get to specifics
Last edit: 10 Feb 2012 10:49 by ArcEye.
10 Feb 2012 11:37 #17547 by Rick G
Replied by Rick G on topic Re:Remote control setup
You may also want to look at step 2 here...
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant
to see if the device is found
Also take a look here...
hidcomp.sourceforge.net/
Rick G
10 Feb 2012 14:16 #17560 by BigJohnT
Replied by BigJohnT on topic Re:Remote control setup
I second Rick about seeing if the device is found then add it to your hal file (don't forget to addf to a thread) and then just open up the Machine > Show HAL Configuration window in Axis and add all the pins for the device to the watch window then start pressing buttons to see which one is which.
10 Feb 2012 15:15 #17563 by tommy
Replied by tommy on topic Re:Remote control setup
less /proc/bus/input/devices
gives me following:
I: Bus=0003 Vendor=04d9 Product=1203 Version=0111
N: Name="HID 04d9:1203"
P: Phys=usb-0000:00:1d.2-2/input0
S: Sysfs=/devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.0/input/input6
U: Uniq=
H: Handlers=kbd event6
B: EV=120013
B: KEY=10000 7 ff800000 7ff febeffdf f3cfffff ffffffff fffffffe
B: MSC=10
B: LED=7
P: Phys=usb-0000:00:1d.2-2/input1
S: Sysfs=/devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.1/input/input7
U: Uniq=
H: Handlers=kbd event7
B: EV=13
B: KEY=2000000 39fa d941d001 1e0000 0 0 0
B: MSC=10
What should be correct name to put after -KRAL ?
I tried some combinations, but causing error on startup emc2 like:
Debug file information:
No input devices could be opened. This usually indicates a misconfigured
system. Please read the section 'PERMISSIONS AND UDEV' in the hal_input
manpage
my-5axis.hal:20: hal_input exited without becoming ready
2599
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
10 Feb 2012 15:43 #17566 by BigJohnT
What names did you try?
10 Feb 2012 15:47 #17568 by BigJohnT
And did you notice the instructions at the bottom of the Simple Remote Pendants page?
10 Feb 2012 15:53 #17571 by andypugh
Replied by andypugh on topic Re:Remote control setup
That appears to be a keyboard. (Which is not surprising if the device claims to work as a keyboard emulator)
If you unplug the pendant and re-run the command, which device disappears? It could get tricky if that pendant has exactly the same USB name as your real keyboard.
10 Feb 2012 18:39 #17580 by tommy
If I unplug it, that HID device disappears, so I guess that is the right recognition of it...
10 Feb 2012 18:52 #17581 by andypugh
Try 04d9 as the name then.
Time to create page: 0.186 seconds
