Remote control setup
Have a look at the main wiki page
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_X11_Joystick_Driver
and several other pages on the same subject under the heading Adding external controls
especially this one wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...ove_Your_CNC_Machine
The principles of allocating keystrokes to USB joystick buttons etc are the same
John has plenty of knowledge re this one when you get to specifics
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant
to see if the device is found
Also take a look here...
hidcomp.sourceforge.net/
Rick G
gives me following:
I: Bus=0003 Vendor=04d9 Product=1203 Version=0111
N: Name="HID 04d9:1203"
P: Phys=usb-0000:00:1d.2-2/input0
S: Sysfs=/devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.0/input/input6
U: Uniq=
H: Handlers=kbd event6
B: EV=120013
B: KEY=10000 7 ff800000 7ff febeffdf f3cfffff ffffffff fffffffe
B: MSC=10
B: LED=7
P: Phys=usb-0000:00:1d.2-2/input1
S: Sysfs=/devices/pci0000:00/0000:00:1d.2/usb8/8-2/8-2:1.1/input/input7
U: Uniq=
H: Handlers=kbd event7
B: EV=13
B: KEY=2000000 39fa d941d001 1e0000 0 0 0
B: MSC=10
What should be correct name to put after -KRAL ?
I tried some combinations, but causing error on startup emc2 like:
Debug file information:
No input devices could be opened. This usually indicates a misconfigured
system. Please read the section 'PERMISSIONS AND UDEV' in the hal_input
manpage
my-5axis.hal:20: hal_input exited without becoming ready
2599
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
That appears to be a keyboard. (Which is not surprising if the device claims to work as a keyboard emulator)
If you unplug the pendant and re-run the command, which device disappears? It could get tricky if that pendant has exactly the same USB name as your real keyboard.
If I unplug it, that HID device disappears, so I guess that is the right recognition of it...
