Remote control setup
10 Feb 2012 19:06 #17582 by tommy
Replied by tommy on topic Re:Remote control setup
andypugh wrote:
Try 04d9 as the name then.
Tried, but getting the same error, also with using 1203, and yes Vendor number is the same as for my usb keyboard .. probably that causing problem?
10 Feb 2012 19:22 #17583 by andypugh
Replied by andypugh on topic Re:Remote control setup
The identification string needs to be unique, so if the vendor-ID is the same, you need to use something else.
However, it is quite likely to also be a problem with the udev rules, which has a small mention at the bottom of the page that JT referenced and in a bit more detail here:
www.linuxcnc.org/docview/html/man/man1/hal_input.1.html
10 Feb 2012 20:02 #17584 by tommy
I created file 51-plugdev.rules in /etc/udev/rules.d
Should I paste exactly this line in it, or I need to modify it to my case (device)?
SUBSYSTEM=="input", mode="0660", group="plugdev"
10 Feb 2012 20:37 - 10 Feb 2012 20:38 #17585 by BigJohnT
Replied by BigJohnT on topic Re:Remote control setup
Only if you want to only enable that device...
From the man page:
By default, the input devices may not be accessible to regular users--hal_input requires read-write access, even if the device has no outputs. To change the default permission of a device, add a new file to /etc/udev/rules.d to set the device’s GROUP to "plugdev". You can do this for all input devices with this rule:
You can also make more specific rules for particular devices. For instance, a SpaceBall input device uses the ’spaceball’ kernel module, so a udev entry for it would read:
DRIVER=="spaceball", MODE="0660", GROUP="plugdev"
the next time the device is attached to the system, it will be accessible to the "plugdev" group.
For USB devices, the udev line would refer to the device’s Vendor and Product values, such as
SYSFS{idProduct}=="c00e", SYSFS{idVendor}=="046d", MODE="0660", GROUP="plugdev"
for a particular logictech-brand mouse.
Last edit: 10 Feb 2012 20:38 by BigJohnT.
12 Feb 2012 17:28 #17629 by tommy
Does thees rules in 51-plugdev.rules file excluding each other, and do I need to run any comp or install after adding it?
12 Feb 2012 19:48 #17630 by BigJohnT
I think you just need to reboot so the new rules will be used.
19 Feb 2012 11:48 #17824 by Rick G
Replied by Rick G on topic Re:Remote control setup
Did you get this working?
Rick G
19 Feb 2012 23:12 #17849 by tommy
Rick G
Sorry, didn't get any further with this...
I found also this one, but I don't know if it would be possible to make it work also with emc2:
LINK
20 Feb 2012 13:08 #17857 by andypugh
It really ought to be possible to make it work. I would offer to investigate, but I am about to disappear for several weeks.
LINK
Driving the LCD from LinuxCNC would require a new driver. I am sure it could be done, but would require some programming I think.
20 Feb 2012 17:05 #17869 by tommy
I found this, probably would need some of this skills to program that one form ebay:
Lathe Pendant
Genreic HID
hidcomp
If there is anyone interested to go for it :)
Time to create page: 0.159 seconds
