Configuring LinuxCNC
Advanced Configuration
Trying to configure XYZU 4 axis setup.
Thank you received: 1224
20 Aug 2012 20:55 - 20 Aug 2012 20:57 #23436
by BigJohnT
You have the line that sends the position commands to stepgen.3 commented out so stepgen.3 does nothing.
And thanks for zipping them up it makes the posts easier to follow when files are attached instead of pasted.
Last edit: 20 Aug 2012 20:57 by
BigJohnT.
Thank you received: 2
20 Aug 2012 21:32 - 20 Aug 2012 21:34 #23438
by BigJohnT
Should be stepgen.3.position-fb, you have an axis 6 but only 0-4 stepgens.
Are you sure that was the error?
Last edit: 20 Aug 2012 21:34 by
BigJohnT.
20 Aug 2012 21:39 #23440
by BigJohnT
This is the error I get.
test_3D-Printer.hal:93: Pin 'axis.6.motor-pos-cmd' was already linked to signal 'upos-cmd'
20 Aug 2012 21:42 #23441
by Gadget047
"When I change the line to this net upos-fb stepgen.3.position-fb => axis.6.motor-pos-fb EMC opens but I get a joint 6 following error
20 Aug 2012 21:47 - 20 Aug 2012 21:49 #23443
by BigJohnT
You have several errors so quicker for me to just fix them. Also as mentioned before your velocity and acceleration for axis U is much higher than a parallel port can muster so you get following errors. When I slow down the jog speed I have no problems jogging U.
Last edit: 20 Aug 2012 21:49 by
BigJohnT.
20 Aug 2012 21:58 #23444
by Gadget047
I have movement but got the joint error on 6 probably due to the acceleration. Do I need to change this in the stepconf file or somewhere in the ini or hal file. what are good settings to start out with?
Thank you received: 4788
20 Aug 2012 22:04 #23446
From now on, ignore Stepconf. You have made changes that will be over-writtten by it.
Having said that, the best way to find the velocity and accel limits of the axis is with Stepconf, so create a new, throwaway, config driving you U p-port pins as X and use the "Test this axis" button to figure out the limits.
Time to create page: 0.299 seconds
