4 axis cnc winch style foam hotwire configuration
05 Oct 2012 19:46 #25007 by BigJohnT
The file is corrupt.
05 Oct 2012 19:48 #25009 by mt92
What should I do?
Thanks for the help guys. I was about ready to build a convention foam cutter, and I really like this concept.
05 Oct 2012 19:50 #25010 by BigJohnT
Open the file manager and select all the files in your configuration directory then right click on them and choose compress then change the compression type to zip. Then attach that file.
05 Oct 2012 20:00 #25012 by mt92
Try this
File Name: config-45e...ee82.zip
File Size:13 KB
05 Oct 2012 20:11 #25014 by BigJohnT
Are you running my-mill.ini or hotwinch.ini? my-mill doesn't have halui, which can be added using the stepconf wizard on about the third page check off "include halui..."
05 Oct 2012 20:22 #25016 by mt92
This is what I have now.
05 Oct 2012 20:23 #25017 by mt92
05 Oct 2012 20:36 #25018 by BigJohnT
Did you add halui?
If you drag the screenshot window off of the one your taking a screenshot of it is much clearer for everyone...
05 Oct 2012 20:42 #25020 by mt92
Sorry here is the top
05 Oct 2012 20:43 #25021 by mt92
Time to create page: 0.103 seconds
