At_pid configuration question
30 Oct 2012 18:58 #26054
by viski
Check my hal file and tell me if i had to add or mofified to start auto tune pid. It starts with no error but pid still works at it would be normal PID .
At_pid configuration question was created by viski
30 Oct 2012 20:48 #26064
Replied by andypugh on topic At_pid configuration question
Tune-mode and tune-start are linked to the Xstart and Xaxis signals, but there is no sign (in that HAL file) of anything to set those signals to "true" to start the process.
There may be a GUI and buttons that do that, though.
Otherwise you probably need to open a terminal and "halcmd sets Xstart true"
(and the same for the Xaxis signal).
Be warned, all I have heard about at_pid is that it isn't very good. I have never tried it though.
I am a bit surprised to find emcmot.... pins in your HAL file. What version of LinuxCNC are you using?
30 Oct 2012 21:39 #26067
by viski
Replied by viski on topic At_pid configuration question
I am useing emc 2.5.1 , latest version.
So, i have to add:
sets Xaxis true
sets Xstart true
sets Zaxis true
sets Zstart true
Well , i have problems with normal PID tuning. Motor is singing or oscilate.
I have brushed DC servo motors with tacho generators feedback. - velocity mode analog servo drives and mesa m5i20 and 7i33 with analog output.
So, i have to add:
sets Xaxis true
sets Xstart true
sets Zaxis true
sets Zstart true
30 Oct 2012 21:43 #26068
You also might need to tune the velocity loop in the drive.
You might find that manual tuning works better.Well , i have problems with normal PID tuning. Motor is singing or oscilate.
31 Oct 2012 00:34 #26086
by viski
Yes, i will try tune servo drive for velocity mode and see results.
Thank you!
Thank you!
31 Oct 2012 18:24 #26121
by BigJohnT
Have you seen my servo tuning tutorial?
gnipsel.com/linuxcnc/tuning/servo.html
Replied by BigJohnT on topic At_pid configuration question
Time to create page: 0.119 seconds
