Spindle Tool
22 Jan 2013 17:33 #28947 by tld70
Replied by tld70 on topic Spindle Tool
Hello ArcEye,
i need a spindle orientation,
now i have seen in version 2.6 there are pins motion.spindle-orient.
i think this will work, but not sure.
can I use your IO also in version 2.6
Thomas
22 Jan 2013 17:50 #28951 by ArcEye
Replied by ArcEye on topic Spindle Tool
Hi
No, not without changes, the code for iocontrol changed in 2.6, but I have posted a version of orient for 2.5.1 on your other post
22 Jan 2013 20:58 #28965 by ArcEye
Hi
That proved far easier than anticipated, did all the edits directly in diff
I have built and run the new version against a RIP install of 2.6-pre~. Works as it should, exactly like the 2.5 version, same pin names etc.
I have included a binary which should just run under 2.6 on 10.04 plus the code if you need to re-compile
File Name: ioControl-2-6.zip
File Size:76 KB
22 Jan 2013 22:08 #28968 by tld70
Thanks for your fast help.
But Linuxcnc dont start up with your IO
it starts with the original IO
attached is the error file
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.0-pre0-3718-g4a5c53e
Machine configuration directory is '/home/chironfz16/linuxcnc/configs/demo_sim_cl'
Machine configuration file is 'demo_sim_cl.ini'
INIFILE=/home/chironfz16/linuxcnc/configs/demo_sim_cl/demo_sim_cl.ini
PARAMETER_FILE=demo_sim_cl.var
TASK=milltask
HALUI=
DISPLAY=axis
DISABLE_SERVER=
SERVER_PATH=
SERVER_ARGS=
SERVER_LOG=
Starting LinuxCNC...
Starting redis server program:
redis server started as: 'redis-server ', logging to: /dev/null
io started
libnml/cms/cms_cfg.cc 622: cms_config: can't open '/usr/src/build-2.6.0~pre/configs/common/linuxcnc.nml'. Error = 2 -- No such file or directory
libnml/nml/nml.cc 368: NML: cms_config returned -1.
* Current Directory = /home/chironfz16/linuxcnc/configs/demo_sim_cl
* BufferName = toolCmd
* ProcessName = tool
* Config File = /usr/src/build-2.6.0~pre/configs/common/linuxcnc.nml
* error_type = 0 (NML_NO_ERROR)
* BufferName = toolSts
* BufferName = emcError
* error_type = 3 (NML_INVALID_CONFIGURATION)
halcmd loadusr io started
INFO CLASSICLADDER- No ladder GUI requested-Realtime runs till HAL closes.
Killing task linuxcncsvr, PID=5099
Killing task redis-server, PID=5098
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
Can not find -sec REDIS -var DISABLE_SERVER -num 1
Can not find -sec REDIS -var SERVER_PATH -num 1
Can not find -sec REDIS -var SERVER_ARGS -num 1
Can not find -sec REDIS -var SERVER_LOG -num 1
emcToolCmd buffer not available
toolSts buffer not available
emcError buffer not available
can't connect to NML buffers in /usr/src/build-2.6.0~pre/configs/common/linuxcnc.nml
<commandline>:0: io exited without becoming ready
demo_sim_cl.hal:28: Pin 'iocontrol.0.user-enable-out' does not exist
5099
PID TTY STAT TIME COMMAND
5098
5098 ? Dl 0:00 redis-server
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 2035.638451] I-pipe: Domain RTAI registered.
[ 2035.638461] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 2035.638463] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 2035.638468] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 2035.638470] PIPELINE layers:
[ 2035.638473] f8367e20 9ac15d93 RTAI 200
[ 2035.638475] c085cb20 0 Linux 100
[ 2035.658880] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2035.659027] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 2035.659031] RTAI[sched]: hard timer type/freq = APIC/12470070(Hz); default timing: periodic; linear timed lists.
[ 2035.659034] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2194516000 hz.
[ 2035.659037] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 2035.659140] RTAI[usi]: enabled.
[ 2035.741437] RTAI[math]: loaded.
[ 2035.815087] creating ladder-state
[ 2036.306749] RTAI[math]: unloaded.
[ 2036.367381] SCHED releases registered named ALIEN RTGLBH
[ 2036.380894] RTAI[malloc]: unloaded.
[ 2036.480014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2036.483101] I-pipe: Domain RTAI unregistered.
[ 2036.483110] RTAI[hal]: unmounted.
22 Jan 2013 23:04 - 22 Jan 2013 23:08 #28973 by ArcEye
Yeah, I forgot that linuxcnc.nml was hard coded, we had this trouble last time. :angry:
I built the module from a RIP install, you will need to build 2.6 from sources and substitute the the ioControl.cc file in the zip for the one at ../src/emc/iotask/ and then the paths will be in the right place.
Hang fire for a little while though whilst I try to reconfigure the --prefix setting without actually installing anything
Last edit: 22 Jan 2013 23:08 by ArcEye.
22 Jan 2013 23:15 #28974 by ArcEye
OK
Try this one, I can't test it because the path prefix is different to that on my machine, but it should match that of an install rather than a RIP build
File Name: ioControl-2-6-mk2.zip
File Size:67 KB
The following user(s) said Thank You: tld70
23 Jan 2013 00:17 #28977 by tld70
Hi ArcEye,
I installed and it works www.linuxcnc.org/media/kunena/emoticons/smile.png
The next few days I will implent the orient and test.
Thank you
Thomas
23 Jan 2013 00:58 #28978 by ArcEye
You're welcome
I have never tried using orient so will be interested to see how you get on
Time to create page: 0.108 seconds
