- Configuring LinuxCNC
- Advanced Configuration
- Servo Wiring and Tuning detailed How To example Mesa 7i77.
20 Jul 2022 14:31 - 20 Jul 2022 14:32 #247851
Replied by PCW on topic Servo Wiring and Tuning detailed How To example Mesa 7i77.
I would disable feedback (you can do this on a per joint basis by setting P, I, and D to 0)
and then set the output voltage by setting the PID bias parameter. (you can set this live with
the calibrate menus "Test" button)
This should allow you to:
1. Check the 7I77 output voltages (7I77 unconnected to drive)
2. Check the drive behaviour when set voltage are applied from the 7I77 (7I77 connected)
Last edit: 20 Jul 2022 14:32 by PCW.
- Monkey_boy
20 Jul 2022 15:02 #247854
by Monkey_boy
Replied by Monkey_boy on topic Servo Wiring and Tuning detailed How To example Mesa 7i77.
The maximum voltage I can get out of the 7i77 is 0.096v (disconected) and 0.078 connected, it doesn`t matter what value is in the bias field there is no change in output voltage from the 7i77 when you press the test button.
Assuming linuxcnc is ok then to me its pointing to the 7i77. what do you think ??
20 Jul 2022 16:33 #247858
I would check
hm2_5i25.0.7i77.0.1.analogena
and
hm2_5i25.0.7i77.0.1.analogout0
with halshow
if analogena is true, analogout0 is +10 you have no real-time warnings
(and OUTPUT_SCALE is 10) and you don't get close to 10V on the 7I77
analog output 0 (7I77 TB5 pin 4 relative to TB5 pin 3) Then there is likely a
problem with the 7I77
and
with halshow
- Monkey_boy
03 Aug 2022 16:02 #248944
by Monkey_boy
Hi I did the test with no result and after purchasing another 7i77 this cured the problem, now I`ve just got to learn servo tuning ??
- Topic Author
- Thank you received: 5918
03 Aug 2022 21:06 #248972
The following user(s) said Thank You: JPL
- Topic Author
30 Oct 2022 15:23 #255445
Replied by tommylight on topic Servo Wiring and Tuning detailed How To example Mesa 7i77.
Changed the title to reflect wiring since a lot of detail is about wiring and testing practices.
30 Oct 2022 17:21 #255464
by JPL
Replied by JPL on topic Servo Wiring and Tuning detailed How To example Mesa 7i77.
Great! Was wondering where this went!
Now, can someone edit this older post to reflect the new url: forum.linuxcnc.org/10-advanced-configura...7i77?start=80#143677
(404)
(404)
- Topic Author
30 Oct 2022 19:52 #255478
04 Jan 2023 03:30 - 04 Jan 2023 09:30 #260891
by petmakris
Replied by petmakris on topic Servo Wiring and Tuning detailed How To example Mesa 7i77.
Amazing how-to, thanks, great starting point for me.
I find this video with a basic overview of the tuning method to provide quite supplementary information
Ziegler-Nichols Method
Last edit: 04 Jan 2023 09:30 by petmakris.
Time to create page: 0.130 seconds
