Relay control without interrupting axis movement.
26 Jan 2011 14:36 #6842
by bnion
Relay control without interrupting axis movement. was created by bnion
Dear all,
I built a paste dispensing system based on an old xyz-robot. The process went smootly and I'm really impressed by the capabilities of EMC2.
I have only one problem: I want to interrupt the dispensing of paste while the robot is running continously. If the speed of the dispenser decelerates the dispenser will add and excessive amount of paste to a single location.
A typical work cycle would be:
-start dispensing
-run a circle
-switch the dispenser off (while not stopping)
-run one or two "dry" cirles to get an even result.
If I use "spindle on/off" g-code to control the dispenser, the axis will always stop when the relay switches state. Same thing seems to happen even if I use other outputs. I would appreciate any help in getting this problem solved.
-bnion
-start dispensing
-run a circle
-bnion
26 Jan 2011 15:24 #6843
by BigJohnT
Replied by BigJohnT on topic Re:Relay control without interrupting axis movement.
26 Jan 2011 15:43 #6844
by bnion
Replied by bnion on topic Re:Relay control without interrupting axis movement.
Thanks John. This is exactly what I was looking for.
Time to create page: 2.840 seconds
