SOLVED: input 13 pin to pause current operation
10 Apr 2011 07:56 - 10 Apr 2011 11:57 #8730 by JohnoInc
Hardware
Probotix FireBall V90
Software
EMC 2.3.3
Hi all.
What i am trying to do is, using a estop switch not to stop the operation as a normal estop. but, trying to get it to just PAUSE the current operation.
the reason is that by pausing the operation when i unpause it will start form the line i paused it at instead of starting at line 1, which is what estop makes it do.
How to: i intend to connect the switch to pin 13 on the parallel port. i haven't worked it out and can't find any instructions in the forum or other forums....
PROCESS: pushing a momentary switch will change value on pin 13 of the break out board instructing the computer to pause operation, exactly like if you push the "P" key on your keyboard
ALL HELP WELCOMED! thank you
Last edit: 10 Apr 2011 11:57 by JohnoInc.
10 Apr 2011 12:00 #8740 by JohnoInc
Thanx mate. solved everything i needed for that function. little over my head, so doing more reading from the links you provided to learn. thank you again for fast reply mate
Time to create page: 0.124 seconds
