disable home button while running
in the below example, how do you know which sig to connect to halui.program.is-idle(pin).
when i try to make another pin, that's my problem.i know i can do this;
net home-in-manual and2.0.in1 and2.1.in1 and2.2.in1 <= halui.mode.is-manual
that works. but if i'm only making one button, i don't need to have all those pins.
net rapid-home and2.3.in0 <== pyvcp.rapid-to-home
net all-rapid and2.3.in1 <== halui.program.is-idle
net remote-rapid-home halui.mdi-command-00 ==> and2.3.out
So is your task to protect the rapid home button like you did the others?
net all-rapid and2.3.in1 <== halui.program.is-idlenet home-in-manual and2.0.in1 and2.1.in1 and2.2.in1 <= halui.mode.is-manual
net remote-rapid-home halui.mdi-command-00 ==> and2.3.out[/quote]
Yes, if you only have one button, (with one pyvcp pin) then you only need one and2 function.
John says "You are not making pins" and this is largely correct, except that the XML file that creates the pyvcp does create pins, (beginning with pyvcp. ) and each MDI_COMMAND in the INI file creates a pin (always an input pin)
(For clarity, information flows out of output pins, and in to input pins)
A signal is a name that has special power. In this example we will use a light circuit.
The signal is outside-lights
the out pin is the wall-switch
the in pins are 4 outside-lights
So when the wall switch is turned on the lights come on, but something else happens the signal is also "on" when the switch is "on". So if I "connect" the signal to more lights they will also come on and off by the switch
Our example would look like this
net outside-lights wall-switch outside-light-1 outside-light-2
to connect up more lights we can do like this
net outside-lights outside-light-3
net outside-lights outside-light-4
or put it all on one line like this
net outside-lights wall-switch outside-light-1 outside-light-2 outside-light-3 outside-light-4
Does this help?
i know,the pins are there already. i can't change them as andypugh said. just
trying to connect them.
don't know what you mean by protect. the second line is the protection?
i know net "connects". then the "name-i-choose"(always here)
then (any order)pin or sig(depending on what i'm doing).
i know if pin is "out", i can't change that,as with "in".
what i can't get is why(how) you picked halui.program.is-idle
as the sig.? halui.program.is-idle is an "out" pin. they were other"out"
pin to choose from. i can't use that pin again and i want to understand,
in another and2 how do i know "which" to choose.any "in" or "out"(whichever
i need at the time) that is not being used ?
net all-rapid and2.3.in1 <== halui.program.is-idle <---if i change this to halui.mode.is-joint,it works but doesn't do what i want
#net zero-all and2.4.in0 <== pyvcp.home-all
#net zero-home and2.4.in1 <== halui.mode.is-joint <
picking a sig that will not change what and2.4.out does.
#net zero-all-home halui.home-all ==> and2.4.out
and2.4.in1 is "in" and "mode.is-joint" is "out" and mode.is-manual and "out. manual works. joint not so much
Did my example above make any sense?
reading it now, just saw it
i think i'm have trouble is when i have "more" then one "switch"
i have to choose a "switch" that can do more then just turn lights on.
there are multiple "switches" that can do the same thing.
The signal is outside-lights <
wouldn't this be the electric "in"
the in pins are 4 outside-lights <
and the wall-switch connecting these
