disable home button while running
19 Apr 2011 14:48 #9086
by piasdom
Replied by piasdom on topic Re:disable home button while running
i did, as i change the dpi, all window and desktop fonts got smaller.
had axis opened and just the title bar changed.none of the buttons.
19 Apr 2011 15:36 - 19 Apr 2011 15:43 #9089
by piasdom
do i use and2 to link the "x" jog button to the pin? and do i use halui or axisui for
jog pins ? too many pins
axis pins ?
axis pins ?
Last edit: 19 Apr 2011 15:43 by piasdom.
19 Apr 2011 17:14 #9091
by piasdom
i try to open a separate pyvcp(emc closed) by using
pyvcp MyVCP.xml i a terminal.(used pyvcp -c mypanel MyVCP.xml as well)
and get error;
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
Error: Multiple components with the same name.
is there another command i can't find ?
and get error;
19 Apr 2011 17:25 - 19 Apr 2011 17:26 #9094
by BigJohnT
Replied by BigJohnT on topic Re:disable home button while running
From the manual:
www.linuxcnc.org/docview/html/hal_pyvcp.html#r1_5
So to load your pyvcp panel use:
The minimum command to load a pyvcp panel is:
loadusr pyvcp mypanel.xml
loadusr pyvcp MyVCP.xml
Last edit: 19 Apr 2011 17:26 by BigJohnT.
19 Apr 2011 17:30 #9096
by piasdom
Thanks, i thought it was a hal command and i needed to
be in hal.
be in hal.
19 Apr 2011 17:33 #9097
by piasdom
i tried that and loadusr -Wn mypanel pyvcp -g 250x500+800+0 -c mypanel mypanel.xml (with my file name)
and i get loadusr; command not found
19 Apr 2011 18:15 #9101
by BigJohnT
Well seems like that is only part of the command, you have to have hal up and running first
Try that.
halrun
Try that.
19 Apr 2011 18:19 #9103
by piasdom
cool, never used hal like that.
THANKS
THANKS
19 Apr 2011 19:05 #9113
by piasdom
can i refresh the panel instead of restarting loadusr pyvcp MyVCP.xml?
want to see the changes to the buttons.
19 Apr 2011 19:14 #9116
by piasdom
and is there a place i can post my xml file so it can help someone
down the road. maybe the postgui as well?
