disable home button while running
19 Apr 2011 19:31 #9119
by BigJohnT
Replied by BigJohnT on topic Re:disable home button while running
I think you have to restart halrun.
You could post it here or the wiki.
20 Apr 2011 09:27 #9156
by piasdom
Replied by piasdom on topic Re:disable home button while running
ok, don't know how to post to wiki
but the attached is for others that may need a small step.
this is the xml file, i'll attach the hal file in next post.
20 Apr 2011 09:32 #9157
by piasdom
this is the hal file i used to make my buttons on a sherline 5400 cnc mill
with stepper motors. the file(MyPVC.xml) and this file i used to make these buttons.
20 Apr 2011 09:34 #9158
by piasdom
oos....the Jog Axis buttons are not linked as i'm still working on those.
20 Apr 2011 10:15 - 20 Apr 2011 10:18 #9162
by piasdom
ok....back to work. i'm trying to connect the Plus-X,Minus-X button for now.
i have the below and emc starts, but the buttons do nothing. are there
other buttons i should be using ? axis.0...-counts...-enable...-scale ?
net plus-x pyvcp.X-plus <== halui.jog.0.plus
net minus-x pyvcp.X-minus <== halui.jog.0.minus
and do i need to worry/think about he true/false on the pins ?
Last edit: 20 Apr 2011 10:18 by piasdom.
20 Apr 2011 13:44 - 20 Apr 2011 13:45 #9165
by piasdom
well, i have my xml file uploaded here wiki.linuxcnc.org/cgi-bin/emcinfo.pl?PyVCP (bottom of page)
but the link doesn't work.
it goes here
wiki.linuxcnc.org/cgi-bin/emcinfo.pl. i uploaded the file and it(site) gave me the link.
it goes here
Last edit: 20 Apr 2011 13:45 by piasdom.
20 Apr 2011 17:33 - 20 Apr 2011 17:33 #9170
by piasdom
here's the completely functioning xml.
Last edit: 20 Apr 2011 17:33 by piasdom.
20 Apr 2011 17:35 - 20 Apr 2011 17:37 #9171
by piasdom
won't let me upload a xml file. just rename it (yourname).xml
it did before
it did before
Last edit: 20 Apr 2011 17:37 by piasdom.
20 Apr 2011 18:10 #9175
Replied by andypugh on topic Re:disable home button while running
Your buttons look nicer than mine, did you find a border-width setting or something?
20 Apr 2011 18:19 #9177
by piasdom
they have
<bd>?</bd> for thickness i think...might be "border dim."
<width>?</width> ones the lowest i can get. not that small.
<height>?</height> again one is the smallest
<fg>"COLOR"</fg> for the foreground
<bg>"COLOR>?</bg> background. don't know if the word of the color needs to be in caps or not.
Time to create page: 0.687 seconds
