disable homing
28 Apr 2011 21:37 - 28 Apr 2011 21:49 #9468
by piasdom
disable homing was created by piasdom
is it possible to disable homing axis when starting ?
i tried NO_FORCE_HOMING in [TRAJ] with no effect. unless i'm
using it wrong. i'm using emc2.4.6 in sim mode.
i can home two axis(any two) but never the third.
Last edit: 28 Apr 2011 21:49 by piasdom.
28 Apr 2011 21:48 #9469
by BigJohnT
Replied by BigJohnT on topic Re:disable homing
What was the complete line?
28 Apr 2011 21:50 #9470
by piasdom
Replied by piasdom on topic Re:disable homing
hope this helps
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.01
NO_FORCE_HOMING = 1
DEFAULT_VELOCITY = 0.28
MAX_LINEAR_VELOCITY = 0.335
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
CYCLE_TIME = 0.01
NO_FORCE_HOMING = 1
28 Apr 2011 21:58 #9471
by piasdom
my first post is incorrect. i can y anytime. if i home z and y,
i can home x. if i home x and y, i can home z
28 Apr 2011 22:11 #9473
by BigJohnT
I'm not sure what your asking... the no force home option when set to 1 means you can jog/run without homing any of the axis. When no force home is set to 0 you are forced to home all axis before you can do anything....
28 Apr 2011 22:14 - 28 Apr 2011 22:28 #9475
by piasdom
i can't home "ALL" the axis. so i need to be able to run a file without homing.
i can only home two axis, if i try to run file, it says can't without homing.
Last edit: 28 Apr 2011 22:28 by piasdom.
28 Apr 2011 22:41 #9477
by BigJohnT
NO_FORCE_HOMING = 1 in the [TRAJ] section should do what you want.
28 Apr 2011 23:44 #9487
by piasdom
it doesn't. but i'll keep looking.
THANKS
THANKS
28 Apr 2011 23:48 #9489
by BigJohnT
Works for me, are you sure you have it in the right section?
29 Apr 2011 18:41 - 29 Apr 2011 18:47 #9516
by piasdom
that got it thanks. don't think i restarted emc
Last edit: 29 Apr 2011 18:47 by piasdom.
Time to create page: 0.107 seconds
