Raspberry Pi 4
30 Dec 2019 23:23 #153578
by Bertho
Replied by Bertho on topic Raspberry Pi 4
Please do not enable any kernel drivers. The hm2_rpspi driver addresses the hardware directly and configures all the necessary internal registers. Having multiple drivers competing over the hardware results in unpredictable behaviour.
At the moment, the hm2_rpspi driver ignores most kernel information about the hardware from the device-tree (that is work in progress) and mostly assumes it knows where to find all the peripherals in the memory map. This could potentially be a problem for port SPI1, but the hardware is supposed to be compatible. The only change was the base-address, which was fixed in the last hm2_rpspi update.
30 Dec 2019 23:47 #153580
by gtt38
Replied by gtt38 on topic Raspberry Pi 4
SPI 0 and 1 have the kernel driver enabled and it's working good on SPI0. I should try to disable both of them.
31 Dec 2019 08:11 - 31 Dec 2019 08:17 #153594
by gtt38
When i'm on SPI0 i have this :
if i'm trying on SPI1/CE2 the same board :
same for CE0 or CE1 with 5 Mhz
with SPI debug :
pi@raspberrypi:~ $ halrun
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_rpspi spi_probe=1 spiclk_rate=5000
hm2/hm2_7i90.0: 72 I/O Pins used:
hm2/hm2_7i90.0: IO Pin 000 (P1-01): PWMGen #0, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 001 (P1-03): PWMGen #0, pin Out1 (Dir or Down) (Outpu t)
hm2/hm2_7i90.0: IO Pin 002 (P1-05): PWMGen #1, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 003 (P1-07): PWMGen #1, pin Out1 (Dir or Down) (Outpu t)
hm2/hm2_7i90.0: IO Pin 004 (P1-09): PWMGen #2, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 005 (P1-11): PWMGen #2, pin Out1 (Dir or Down) (Outpu t)
hm2/hm2_7i90.0: IO Pin 006 (P1-13): PWMGen #3, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 007 (P1-15): PWMGen #3, pin Out1 (Dir or Down) (Outpu t)
hm2/hm2_7i90.0: IO Pin 008 (P1-17): IOPort
hm2/hm2_7i90.0: IO Pin 009 (P1-19): IOPort
hm2/hm2_7i90.0: IO Pin 010 (P1-21): IOPort
hm2/hm2_7i90.0: IO Pin 011 (P1-23): IOPort
hm2/hm2_7i90.0: IO Pin 012 (P1-25): IOPort
hm2/hm2_7i90.0: IO Pin 013 (P1-27): IOPort
hm2/hm2_7i90.0: IO Pin 014 (P1-29): IOPort
hm2/hm2_7i90.0: IO Pin 015 (P1-31): IOPort
hm2/hm2_7i90.0: IO Pin 016 (P1-33): IOPort
hm2/hm2_7i90.0: IO Pin 017 (P1-35): IOPort
hm2/hm2_7i90.0: IO Pin 018 (P1-37): IOPort
hm2/hm2_7i90.0: IO Pin 019 (P1-39): IOPort
hm2/hm2_7i90.0: IO Pin 020 (P1-41): IOPort
hm2/hm2_7i90.0: IO Pin 021 (P1-43): IOPort
hm2/hm2_7i90.0: IO Pin 022 (P1-45): IOPort
hm2/hm2_7i90.0: IO Pin 023 (P1-47): IOPort
hm2/hm2_7i90.0: IO Pin 024 (P2-01): PWMGen #4, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 025 (P2-03): PWMGen #4, pin Out1 (Dir or Down) (Outpu t)
hm2/hm2_7i90.0: IO Pin 026 (P2-05): PWMGen #5, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 027 (P2-07): PWMGen #5, pin Out1 (Dir or Down) (Outpu t)
hm2/hm2_7i90.0: IO Pin 028 (P2-09): PWMGen #6, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 029 (P2-11): PWMGen #6, pin Out1 (Dir or Down) (Outpu t)
hm2/hm2_7i90.0: IO Pin 030 (P2-13): PWMGen #7, pin Out0 (PWM or Up) (Output)
hm2/hm2_7i90.0: IO Pin 031 (P2-15): PWMGen #7, pin Out1 (Dir or Down) (Outpu t)
hm2/hm2_7i90.0: IO Pin 032 (P2-17): IOPort
hm2/hm2_7i90.0: IO Pin 033 (P2-19): IOPort
hm2/hm2_7i90.0: IO Pin 034 (P2-21): IOPort
hm2/hm2_7i90.0: IO Pin 035 (P2-23): IOPort
hm2/hm2_7i90.0: IO Pin 036 (P2-25): IOPort
hm2/hm2_7i90.0: IO Pin 037 (P2-27): IOPort
hm2/hm2_7i90.0: IO Pin 038 (P2-29): IOPort
hm2/hm2_7i90.0: IO Pin 039 (P2-31): IOPort
hm2/hm2_7i90.0: IO Pin 040 (P2-33): IOPort
hm2/hm2_7i90.0: IO Pin 041 (P2-35): IOPort
hm2/hm2_7i90.0: IO Pin 042 (P2-37): IOPort
hm2/hm2_7i90.0: IO Pin 043 (P2-39): IOPort
hm2/hm2_7i90.0: IO Pin 044 (P2-41): IOPort
hm2/hm2_7i90.0: IO Pin 045 (P2-43): IOPort
hm2/hm2_7i90.0: IO Pin 046 (P2-45): IOPort
hm2/hm2_7i90.0: IO Pin 047 (P2-47): IOPort
hm2/hm2_7i90.0: IO Pin 048 (P3-01): IOPort
hm2/hm2_7i90.0: IO Pin 049 (P3-03): IOPort
hm2/hm2_7i90.0: IO Pin 050 (P3-05): IOPort
hm2/hm2_7i90.0: IO Pin 051 (P3-07): IOPort
hm2/hm2_7i90.0: IO Pin 052 (P3-09): IOPort
hm2/hm2_7i90.0: IO Pin 053 (P3-11): IOPort
hm2/hm2_7i90.0: IO Pin 054 (P3-13): IOPort
hm2/hm2_7i90.0: IO Pin 055 (P3-15): IOPort
hm2/hm2_7i90.0: IO Pin 056 (P3-17): IOPort
hm2/hm2_7i90.0: IO Pin 057 (P3-19): IOPort
hm2/hm2_7i90.0: IO Pin 058 (P3-21): IOPort
hm2/hm2_7i90.0: IO Pin 059 (P3-23): IOPort
hm2/hm2_7i90.0: IO Pin 060 (P3-25): IOPort
hm2/hm2_7i90.0: IO Pin 061 (P3-27): IOPort
hm2/hm2_7i90.0: IO Pin 062 (P3-29): IOPort
hm2/hm2_7i90.0: IO Pin 063 (P3-31): IOPort
hm2/hm2_7i90.0: IO Pin 064 (P3-33): IOPort
hm2/hm2_7i90.0: IO Pin 065 (P3-35): IOPort
hm2/hm2_7i90.0: IO Pin 066 (P3-37): IOPort
hm2/hm2_7i90.0: IO Pin 067 (P3-39): IOPort
hm2/hm2_7i90.0: IO Pin 068 (P3-41): IOPort
hm2/hm2_7i90.0: IO Pin 069 (P3-43): IOPort
hm2/hm2_7i90.0: IO Pin 070 (P3-45): IOPort
hm2/hm2_7i90.0: IO Pin 071 (P3-47): IOPort
hm2/hm2_7i90.0: registered
halcmd: loadrt hm2_rpspi spi_probe=16 spiclk_rate=5000
hm2_rpspi: SPI1/CE2 Invalid cookie, read: 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d
hm2_rpspi: SPI1/CE2 No drive seen on MISO line (kept at pull-down level). No board connected or bad connection?
hm2_rpspi: rtapi_app_main: No such device (-19)
<stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_rpspi
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_rpspi failed, returned -1
halcmd:
with SPI debug :
halcmd: loadrt hm2_rpspi spi_probe=16 spi_debug=5 spiclk_rate=5000
hm2_rpspi: Platform: Raspberry Pi 4 Model B Rev 1.1
hm2_rpspi: Base address 0xfe000000 size 0x01800000
hm2_rpspi: Mapped peripherals from 0xfe000000 (size 0x01800000) to gpio:0x0xb4c97000, spi:0x0xb4c9b000, aux:0x0xb4cac000
hm2_rpspi: SPI1/CE2 clock rate: 5000000/5000000 Hz, VPU clock rate: 500000000 Hz
hm2_rpspi: SPI1/CE2 write clock rate calculated: 5000000 Hz (clkdiv=100)
hm2_rpspi: SPI1/CE2 read clock rate calculated: 5000000 Hz (clkdiv=100)
Last edit: 31 Dec 2019 08:17 by gtt38.
31 Dec 2019 09:47 #153597
by gtt38
i tested CE0 or CE1 on SPI1 with 5Mhz, i hope it could help you to debug :
CE0 :
CE1:
@Bertho : I can run some test for you if you need to modify your driver.
CE0 :
halcmd: loadrt hm2_rpspi spi_probe=4 spi_debug=5 spiclk_rate=5000
hm2_rpspi: Mapped peripherals from 0xfe000000 (size 0x01800000) to gpio:0x0xb4c86000, spi:0x0xb4c8a000, aux:0x0xb4c9b000
hm2_rpspi: SPI1/CE0 clock rate: 5000000/5000000 Hz, VPU clock rate: 500000000 Hz
hm2_rpspi: SPI1/CE0 write clock rate calculated: 5000000 Hz (clkdiv=100)
hm2_rpspi: SPI1/CE0 read clock rate calculated: 5000000 Hz (clkdiv=100)
hm2_rpspi: SPI1/CE0 Invalid cookie, read: 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d
hm2_rpspi: SPI1/CE0 No drive seen on MISO line (kept at pull-down level). No board connected or bad connection?
halcmd:
CE1:
halcmd: loadrt hm2_rpspi spi_probe=8 spi_debug=5 spiclk_rate=5000
hm2_rpspi: Mapped peripherals from 0xfe000000 (size 0x01800000) to gpio:0x0xb4cf4000, spi:0x0xb4cf8000, aux:0x0xb4d09000
hm2_rpspi: SPI1/CE1 clock rate: 5000000/5000000 Hz, VPU clock rate: 500000000 Hz
hm2_rpspi: SPI1/CE1 write clock rate calculated: 5000000 Hz (clkdiv=100)
hm2_rpspi: SPI1/CE1 read clock rate calculated: 5000000 Hz (clkdiv=100)
hm2_rpspi: SPI1/CE1 Invalid cookie, read: 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d
hm2_rpspi: SPI1/CE1 No drive seen on MISO line (kept at pull-down level). No board connected or bad connection?
halcmd:
31 Dec 2019 11:51 #153599
by Bertho
Hmm, the whole of SPI1 is not working. There is no data at all read back, it seems.
Do you know whether data actually gets sent out? You have your own FPGA setup; maybe you can put an oscilloscope on the lines and see whether this is a read problem or a complete fail on all the SPI1 lines? That may narrow the problem down.
Also, do you have a RPi3? Now I am wondering if the older version actually still works. You should be able to swap the SD card and boot if you have not locked the kernel to the new SoC.
31 Dec 2019 19:10 #153631
by gtt38
unfortunately I locked the kernel to the new SoC.
But i own a raspberry pi 3 and i found a image on Gene website so i'm gonna try
01 Jan 2020 20:36 - 01 Jan 2020 20:37 #153734
by gtt38
Just tried with a RPi3 and unfortunatly the only image that i found on Gene website is an old one (dec 2016)
HM2_rpspi seems to be really old ("spi_probe=16" is unreconized same for "spi_debug")
i have a too small oscilloscope (1 mhz max) so it will be difficult to monitor SPI1
Last edit: 01 Jan 2020 20:37 by gtt38.
01 Jan 2020 21:35 #153739
by Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <geneslinuxbox.net:6309/gene>
Replied by Gene1934 on topic Raspberry Pi 4
You didn't look in the right place. Add /lathe-stf to the link in my sig, which should get you a directory containing linixcnc4rpi4, click on that and you'll find a build but not stripped kernel, and the debs that are running linuxcnc on my rpi4 and have been for a couple months. The debs ae ready to install and supposedly have Bertho's latest rpspi. driver. I couldn't make the read and write speed commands work, and my lashup will not read from a 7i90HD any faster that 25 megabits, so the code is hard built for a 31 megabit write and a 25 megabit read. Untested with the other two cards.
That kernel contains the newer much faster video drivers and will make 60 fps glxgears on a full 1920x1080 screen, which is about 58 fps faster than the older kernel can do.
Sorry the kernel is about 2.5 gigabytes but its fully built, just follow Big Johns instructions to install what you need from it.
I don't have upload bw to spare, so its slow. And I've blocked about 40 of the nets less well trained bots from mirroring my site.
01 Jan 2020 21:41 #153740
by Gene1934
And my blocks are /24 wide. So I you can't get it,, send an email to This email address is being protected from spambots. You need JavaScript enabled to view it., containing your outside ipv4 address and I'll clear that block if you are in its /24 reach, meaning the first 3 numbers match.
Be my guest.
Be my guest.
01 Jan 2020 21:54 #153742
by gtt38
Thanks Gene
I'm downloading your kernel. Seems really promising.
Time to create page: 0.318 seconds
