LinuxCNC + Orange Pi (allwincnc)
30 Aug 2020 02:58 #180005
I don't thnk so but it does have a UART there which with a cheap RS485 chip will open up some options for plasma control.
But it does have 2 x NIC's so its perfect to run a mesa Card, eg 7i76e/7i96.
Replied by rodw on topic LinuxCNC + Orange Pi
OT: Is the "Peripheral Expansion Header (24 pins)" of the Odroid usable for 3 axis step/dir # spindle + 4xinput switch?
02 Sep 2020 13:48 #180433
by MX_Master
Replied by MX_Master on topic LinuxCNC + Orange Pi
You can use any board with Allwinner H3 SoC.Are there any differences between OrangePi and NanaoPi? Any board that you would recommend - or avoid? (I've had RPis working with LinuxCNC, but they were not quite up to the task)
- twoflowers
- User is blocked
- Thank you received: 32
09 Sep 2020 08:12 #181393
by twoflowers
Replied by twoflowers on topic LinuxCNC + Orange Pi
Ok, I ordered an "Orange Pi PC Plus" with H3.
21 Sep 2020 19:18 - 21 Sep 2020 19:20 #183172
by MalteS
Replied by MalteS on topic LinuxCNC + Orange Pi
This is super cool stuff !!!
If I wanted to order a board now should I go for H3, H5 or H6?
I'm looking for decent graphics performance of Axis.
I understand that the driver is ready for H3 and partially for H5 but not for H6 yet. Is that right?
Will it eventually be ported fully?
Thanks,
Malte
Thanks,
Malte
Last edit: 21 Sep 2020 19:20 by MalteS.
- twoflowers
- User is blocked
24 Sep 2020 09:56 - 24 Sep 2020 10:34 #183562
by twoflowers
Might be a stupid question, but where do I get the RT kernel?
EDIT: found it
orangecnc.gitlab.io/quick-start.html
EDIT: found it
Last edit: 24 Sep 2020 10:34 by twoflowers.
24 Sep 2020 10:56 - 24 Sep 2020 11:03 #183568
by fery15sty
Replied by fery15sty on topic LinuxCNC + Orange Pi
i have tried OrangePi_PC with
armbian img:
Armbian_20.02.1_Orangepipc_buster_current_5.4.20_desktop.7z
and I followed the instructions:
git clone gitlab.com/orangecnc/installer
cd installer
./install.sh
but the result failed, and the result is like this picture:
Please help me..
armbian img:
cd installer
./install.sh
Please help me..
Last edit: 24 Sep 2020 11:03 by fery15sty.
- twoflowers
- User is blocked
24 Sep 2020 11:03 #183570
by twoflowers
Network problem, try if you can reach the mentioned hosts that did respond.
The following user(s) said Thank You: fery15sty
24 Sep 2020 11:16 #183572
by fery15sty
can you tell me, how to fix it..
24 Sep 2020 11:20 #183573
by fery15sty
fery@orangepipc:~$ git clone gitlab.com/orangecnc/installer
Cloning into 'installer'...
warning: redirecting to gitlab.com/orangecnc/installer.git/
remote: Enumerating objects: 556, done.
remote: Total 556 (delta 0), reused 0 (delta 0), pack-reused 556
Receiving objects: 100% (556/556), 425.60 MiB | 381.00 KiB/s, done.
Resolving deltas: 100% (272/272), done.
Checking out files: 100% (113/113), done.
fery@orangepipc:~$ cd installer
fery@orangepipc:~/installer$ ./install.sh
--- Installing orangecnc
--- Installing System tweaks
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for fery:
--- System tweaks successfully installed
--- Installing System language
Please select the system language:
1: English
2: Russian
Language: 1
Setting up the 'en_US.UTF-8' as system language...
Generating locales (this might take a while)...
en_US.UTF-8... done
Generation complete.
NOTE: You must relogin or reboot the system to complete the installation
--- System language successfully installed
--- Installing PREEMPT RT kernel
Installing packages ...
Installing ./armbian/preempt_rt_kernel/linux-image-current-sunxi_20.02.3_armhf.deb ...
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 50 not upgraded.
Need to get 0 B/26.5 MB of archives.
After this operation, 151 kB of additional disk space will be used.
(Reading database ... 102528 files and directories currently installed.)
Preparing to unpack .../linux-image-current-sunxi_20.02.3_armhf.deb ...
update-initramfs: Deleting /boot/initrd.img-5.4.20-sunxi
Removing obsolete file uInitrd-5.4.20-sunxi
Unpacking linux-image-current-sunxi (20.02.3) over (20.02.1) ...
Setting up linux-image-current-sunxi (20.02.3) ...
update-initramfs: Generating /boot/initrd.img-5.4.18-rt11-sunxi
update-initramfs: Converting to u-boot format
Installing ./armbian/preempt_rt_kernel/linux-headers-current-sunxi_20.02.3_armhf.deb ...
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 50 not upgraded.
Need to get 0 B/11.1 MB of archives.
After this operation, 75.6 MB of additional disk space will be used.
Selecting previously unselected package linux-headers-current-sunxi.
(Reading database ... 102520 files and directories currently installed.)
Preparing to unpack .../linux-headers-current-sunxi_20.02.3_armhf.deb ...
Unpacking linux-headers-current-sunxi (20.02.3) ...
Setting up linux-headers-current-sunxi (20.02.3) ...
Compiling headers - please wait ...
NOTE: You must reboot the system to complete the installation
--- PREEMPT RT kernel successfully installed
--- Installing LinuxCNC
Installing ./linuxcnc/linuxcnc-uspace_2.7.15_armhf.deb ...
The following additional packages will be installed:
blt bwidget freeglut3 gir1.2-gst-plugins-base-1.0 gir1.2-gstreamer-1.0
gstreamer1.0-plugins-base libcdparanoia0 libglade2-0 libglew2.1 libglu1-mesa
libgtkglext1 libimagequant0 libmodbus5 libpango1.0-0 libpangox-1.0-0
libreadline5 libtk-img libtk8.6 libudev-dev libudev1 libvisual-0.4-0
mesa-utils python-configobj python-gi python-glade2 python-gst-1.0
python-gtkglext1 python-opengl python-pil python-pil.imagetk python-tk
python-xlib tcl tcl-tclreadline tclx8.4 tk tk8.6 tk8.6-blt2.5 udev
Suggested packages:
blt-demo glew-utils libtk-img-doc libvisual-0.4-plugins python-configobj-doc
python-gi-cairo python-gtk2-doc libgle3 python-pil-doc python-pil-dbg
python-pil.imagetk-dbg tix python-tk-dbg tclx8.4-doc
Recommended packages:
linuxcnc-doc-en | linuxcnc-doc hostmot2-firmware-all python-olefile
libreadline5 libtk-img libtk8.6 libudev-dev libvisual-0.4-0 linuxcnc-uspace
libudev1 udev
2 upgraded, 38 newly installed, 0 to remove and 48 not upgraded.
Need to get 9,943 kB/13.5 MB of archives.
After this operation, 51.2 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
E: Failed to fetch httpredir.debian.org/debian/pool/main/s/...-7~deb10u3_armhf.deb 404 Not Found [IP: 151.101.10.133 80]
E: Failed to fetch httpredir.debian.org/debian/pool/main/p/...tk_5.4.1-2_armhf.deb 404 Not Found [IP: 151.101.10.133 80]
E: Failed to fetch httpredir.debian.org/debian/pool/main/p/...il_5.4.1-2_armhf.deb 404 Not Found [IP: 151.101.10.133 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
./install_linuxcnc.sh: line 174: linuxcnc: command not found
ERROR: Failed to install ./linuxcnc/linuxcnc-uspace_2.7.15_armhf.deb package [./install_linuxcnc.sh:175].
--- Installing GPIO driver
./install_gpio_driver.sh: line 73: halcompile: command not found
./install_gpio_driver.sh: line 75: comp: command not found
Can't find a components compiler for the linuxcnc [./install_gpio_driver.sh:78].
--- Installing GPIO configs
--- GPIO configs successfully installed
--- Installing ARISC drivers
./install_arisc_driver.sh: line 73: halcompile: command not found
./install_arisc_driver.sh: line 75: comp: command not found
ERROR: Can't find a components compiler for the linuxcnc [./install_arisc_driver.sh:78].
--- Installing ARISC configs
--- ARISC configs successfully installed
--- Installing ARISC firmware
--- ARISC firmware successfully installed
--- orangecnc installed with errors
--- see the install.log file for details
1: English
2: Russian
Language: 1
en_US.UTF-8... done
Suggested packages:
libudev1 udev
24 Sep 2020 11:32 - 24 Sep 2020 12:19 #183574
by fery15sty
some time ago I also tried the latest version of Armbian:
Armbian_20.08_Orangepipc_buster_current_5.7.15_desktop.img.xz
And the process runs without error, but after rebooting, keyboard and mouse don't work ..
i am confused which version of armbian is suitable for machinekit / linuxcnc
Last edit: 24 Sep 2020 12:19 by fery15sty.
Time to create page: 0.200 seconds
