[SOLVED] How to change the view of the axes in AXIS?
13 May 2022 19:47 - 16 Jul 2022 20:21 #242907
by Nest
[SOLVED] How to change the view of the axes in AXIS? was created by Nest
Hi everyone, when AXIS is opened the direction of the axes do not match my machine,
In AXIS the X axis is down and the Y is to the right
on my machine the Y is down and the X is to the right
the Home of my machine is on the left.
how can i change that view in AXIS to match my machine?
Thanks you so much
Thanks you so much
Last edit: 16 Jul 2022 20:21 by Nest.
- Thank you received: 5906
13 May 2022 22:24 #242913
Replied by tommylight on topic How to change the view of the axes in AXIS?
Some pictures or drawings would help.
13 May 2022 22:56 #242918
by Nest
Replied by Nest on topic How to change the view of the axes in AXIS?
14 May 2022 01:34 #242933
Replied by cmorley on topic How to change the view of the axes in AXIS?
You want to flip the model upside down?
Some lathe views flip the model.
There are some other views but you would need to modify AXIS to use them.
14 May 2022 08:08 #242945
by Nest
yes, i want to flip the view.
someone knows?
someone knows?
- Thank you received: 1369
16 May 2022 17:46 - 16 May 2022 17:46 #243091
Replied by Todd Zuercher on topic How to change the view of the axes in AXIS?
Do you get the view you want if you select "Rotated Top view" in the "View" menu?
Last edit: 16 May 2022 17:46 by Todd Zuercher.
16 May 2022 18:38 #243094
by Nest
16 May 2022 19:15 #243099
On your image you posted, the second choice from the top "Vista superior girada", or the 2nd view Icon choice in the Icon tool bar (the sideways Z).
16 May 2022 20:05 #243106
by Nest
these options change the view but do not change the axes
17 May 2022 23:18 #243219
Replied by andypugh on topic How to change the view of the axes in AXIS?
I am suspicious that your machine is set up wrong. The coordinate system should be right-handed or CAM software (at least) won't work.
You will get mirrored parts, at best.
Time to create page: 0.083 seconds
