Pokeys
02 Dec 2018 22:05 #121730
Whatever else is wrong, you definitely need to loadusr the component before you try to set any of its pins. The pins won't exist until it is loaded.
-W should mean that the loadusr command waits for the component to be ready before continuing.
When you say "Didn't work" what error message do you see?
04 Dec 2018 09:52 - 04 Dec 2018 10:02 #121802
by Erikcnc
This is what i got now.
in my_mill.hal file
in postgui_call_list.hal file
If i use terminal with:
Pokeys response to the switches i installed before. Check, pokeys works.
I close terminal.
I start Linuxcnc (Gmoccapy)
Emergency butten ---> Machine Enable.
Go to settings ---> button Halshow
I go to watch en selecting the pins from the pokeys.
No response from my pre installed buttons.
Eny one got an example how it should look like?
in my_mill.hal file
loadusr -W pokeys
net all-home pokeys.0.in-2 => halui.home-all
setp pokeys.0.devSerial 38163
halrun
halcmd: loadusr -W pokeys
halcmd: setp pokeys.0.devSerial 38163
halshow
I close terminal.
Last edit: 04 Dec 2018 10:02 by Erikcnc.
04 Dec 2018 14:35 - 04 Dec 2018 15:11 #121807
by Erikcnc
I followed the installation from this topic (page 1)
After i continued reading this topic, on page 5 i read this:
My apologizes for my lack of language. I try my best to explain my issue. I really hope to get it to work.
Erik
Ok,I think I've got it!
Yesterday I was testing the system. thinking first in the update I moved my debian wheezy to debian jessi and afterwards tried to update linuxcnc.Everything seemed right until I tried to open my-mill then a linuxcnc error appeared. I thought the issue was because I had created the file in the older version so I created a new one but had no success. Desperate and a little upset I made an afresh installation of debian wheezy, I updated cnclinux and was able to open up the file.
I went back to do all the steps Fixer stated from page 1 and connected the Pokeys in windows to know the serial number. In the file my-mill.hall I wrote loadusr pokeys, ran the linuxcnc and was now able to see the pins. I shut down linuxcnc and now in my-mill.hall I wrote pokeys.0.devSerial 66258 save file and try to open linuxcnc send me an error:Debug file information: . ./my-mill.hal:7: parameter or pin 'pokeys.0.devSerial' not found
I change the code loadusr pokeys and pokeys.0.devSerial to custom.hal and show me an error, if I put the loadusr pokeys in my-mill.hal and pokeys.0.devSerial66258 in custom.hal linuxcnc run fine, and pokeys.0.err are false and pokeys.0.alive start blinking. Is this procedure correct?
I tried to use estop with pokeys to test but i did not get it work, in custom.hal I wrote net estop-ext <= pokeys.0.in-52 it dont send me errors and in HAL configuration the pin 52 show :
Owner Type Dir Value Name
7 bit OUT FALSE pokeys.0.in-52 ==>estop-ext
Thank you so much for your help, have a nice day.
Erik
Last edit: 04 Dec 2018 15:11 by Erikcnc.
04 Dec 2018 14:49 #121808
Is it possible that you need to recompile linked to a different RTAI system?
From the starting post:
There are quite a number of explicit references to a specific RTAI path in there.
gcc -Wall -Os -g -I. -I/usr/include/libusb-1.0 -I/usr/include -L/usr/lib/ -L/usr/lib/arm-linux-gnueabihf/ -lPoKeys -lusb-1.0 -I/usr/realtime-3.4-9-rtai-686-pae/include -I. -I/usr/realtime-3.4-9-rtai-686-pae/include -I/usr/include/i386-linux-gnu -U_FORTIFY_SOURCE -D_FORTIFY_SOURCE=0 -fno-math-errno -funsafe-math-optimizations -fno-rounding-math -fno-signaling-nans -fcx-limited-range -mhard-float -DRTAI=3 -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime -D__MODULE__ -I/usr/include/linuxcnc -Wframe-larger-than=2560 -URTAPI -U__MODULE__ -DULAPI -Os -o pokeys ./pokeys.c -Wl,-rpath,/lib -L/lib -llinuxcnchal
04 Dec 2018 14:53 #121809
No, forget that, it has already been shown to work on your current system.
Try addingafter the "loadusr pokeys" line in the HAL.
Also, start linuxcnc from the command-line (command "linuxcnc") and paste all the output here.
Try adding
show pin
04 Dec 2018 15:14 #121810
by Erikcnc
Oke thanks!
I will try this evening.
Try addingafter the "loadusr pokeys" line in the HAL.show pin
Oke thanks!
06 Dec 2018 08:30 - 06 Dec 2018 08:33 #121931
by Erikcnc
Works like a charm!
Thank you so much for the support!
A overview how it works for me.
in my_mill.hal file
Home-all works also without going to the home tab.
i got also three 10K potetiometer to use as feed, maxvelocity and spindle override.
How could i get this to work though?
in my_mill.hal file
loadusr -W pokeys
show pin
# --- HOME-ALL ---
net all-home pokeys.0.in-2 <= halui.home-all
# ---CYCLE START ---
net program.run pokeys.0.in-0 <= halui.program.run
# ---CYCLE STOP ---
net program.stom pokeys.0.in-3 <= halui.program.stop
Last edit: 06 Dec 2018 08:33 by Erikcnc.
06 Dec 2018 10:35 #121940
Well, that's weird.
"show pin" was only meant as a way to get some output to check if the pin existed. It wasn't meant to fix the problem.
Does the problem un-fix if you take the "show pin" back out again?
I don't see any reason for "setp pokets.0.devSerial" to need to be in the postgui call list.
It looks like some sort of race condition, which is odd as the -W should wait for completion.
Do you have the potentiometer values appearing and changing in HAL?
07 Dec 2018 11:06 #122000
by Erikcnc
I could try to remove 'show pin' and check if its realy that issue.
Another thing, those arrows are they have a function? Does it make a difirents how you insert them? ( <= or => )
About those potentiometers, i set them as analog input with the pokeys software.
I have to check how i can see values insted of I/0 dots.
Well, that's weird.
Time to create page: 0.101 seconds
