7i96 Configuration Tool
- Thank you received: 5924
15 Nov 2019 03:48 #150401
Replied by tommylight on topic 7i96 Configuration Tool
I did remember that i had to do that once a while back and "yes" did not work, but 1 did.
Glad i remembered correctly.
19 Nov 2019 13:58 - 19 Nov 2019 14:24 #150644
by jools
Replied by jools on topic 7i96 Configuration Tool
There seems to be a bug in my system.
I flashed using the tool and the 4 stepgen and 1 PWM. On opening LCNC there were no manual spindle button controls.
I added some HAL as documented in the spindle section of the DOC's and the buttons showed up but clicking on them does nothing to the voltage at the PWM plus and minus pins on the 7i96 which stays at -5v.
Jools
Just tried a brand new configuration to see if I'm going nuts and it threw an error on start up saying
pin 'motion.spindle-forward' does not exist.
Jools
Last edit: 19 Nov 2019 14:24 by jools.
21 Nov 2019 23:28 - 22 Nov 2019 02:21 #150868
by Leon82
Replied by Leon82 on topic 7i96 Configuration Tool
I have communicated with my card using the other pinned thread about setting the connection.
It has the 5 step gen from what I can see from the read button.
Is it as simple as selecting 4 steps gen with pwm and clicking flash?
ETA It appears so
ETA It appears so
Last edit: 22 Nov 2019 02:21 by Leon82.
22 Nov 2019 12:20 #150902
by jools
Leon
Read this thread to get it working properly. forum.linuxcnc.org/38-general-linuxcnc-q...et-pwm-output-solved
Jools
ETA It appears so
Leon
Jools
The following user(s) said Thank You: Leon82
22 Nov 2019 12:46 - 22 Nov 2019 12:47 #150906
by Leon82
Yes I have it bookmarked.did you post the pwm Hal section?
ETA It appears so
Leon
Jools
Last edit: 22 Nov 2019 12:47 by Leon82.
22 Nov 2019 14:05 #150923
by jools
will do now but there seems to be further issues, though again this may be my lack of knowledge. I'll ask PCW and John but it involves the servo overspinning, I think it's a feedback thing from the encoder.
22 Nov 2019 15:49 #150933
by jools
Just to document the issue I'm having after enabling PWM.
The servo spindle that is controlled by the PWM revs up to it's hard limit even at low voltages due to the motor not being under load. So when inputting a low spindle speed of say 1000 rpm it would spin up to the hard limit of 2500. When it starts cutting and the motor goes under load it would then drop it's speed level accordingly.
Is there a way this can be monitored with feedback commands or something similar so that so the spindle speed is limited by linux cnc?
22 Nov 2019 16:03 #150935
Replied by andypugh on topic 7i96 Configuration Tool
Yes, this is a perfect application for a PID controller.
There is an example here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Closed...pindle_Speed_Control
But it isn't a very good one.... It adds the PID output on to the spindle speed command. I presume this is because it is old and dates to a time before the PID component included feed-forward terms.
Basically:
spindle-speed-command => PID command
spindle-speed-feedback => PID feedback
PID-output => PWM value
(ie, the PID is inserted between the spindle command out and the PID command in)
Start with P, I, D all zero and adjust FF0 to give the right speed under no-load. Then adjust I (mainly) and some P to get good stiff speed control.
Be aware of units. Use a revs-per-second spindle speed command, as encoder velocity is in revs-per-second.
Basically:
22 Nov 2019 16:11 - 22 Nov 2019 16:13 #150937
Replied by PCW on topic 7i96 Configuration Tool
Hey, didn't you add the velocity-rpm pin to the software and HM2 encoder?
That simplifies the PID setup
Last edit: 22 Nov 2019 16:13 by PCW.
22 Nov 2019 16:26 #150942
True, I did. But it isn't there on all LinuxCNC versions. .
Time to create page: 0.205 seconds
