7i96 Configuration Tool
22 Nov 2019 18:26 #150957
by jools
So
that would be something like
net spindle_speed spindle.0.speed-out => pid.3.command for the first one (got the pin name from the bit in my hal that links motion to output.
Then I need to look and find the name of the spindle feedback pin and the PID feedback pin
Find the name the PID out put pin and the pwm value pin
The above would come before the standard PID settings / values
Then below all that would come the pwmgen settings I all ready have?
On daddy duty now but if that's correct I'll hunt for pin names later and see if I can figure this out.
Cheers
Jools
Replied by jools on topic 7i96 Configuration Tool
Y
Basically:
spindle-speed-command => PID command
spindle-speed-feedback => PID feedback
PID-output => PWM value
Be aware of units. Use a revs-per-second spindle speed command, as encoder velocity is in revs-per-second.
So
Cheers
Jools
23 Nov 2019 11:36 #151036
by jools
How does this look
Jools
Yes, this is a perfect application for a PID controller.
There is an example here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Closed...pindle_Speed_Control
But it isn't a very good one.... It adds the PID output on to the spindle speed command. I presume this is because it is old and dates to a time before the PID component included feed-forward terms.
Basically:
(ie, the PID is inserted between the spindle command out and the PID command in)
Start with P, I, D all zero and adjust FF0 to give the right speed under no-load. Then adjust I (mainly) and some P to get good stiff speed control.
How does this look
# Spindle
setp hm2_7i96.0.pwmgen.00.output-type 1
setp hm2_7i96.0.pwmgen.00.scale [SPINDLE]MAX_RPM
setp hm2_7i96.0.pwmgen.pwm_frequency [SPINDLE]PWM_FREQUENCY
net spindle_on spindle.0.on hm2_7i96.0.pwmgen.00.enable hm2_7i96.0.ssr.00.out-05
net spindle-speed-feedback hm2_7i96.0.encoder.00.velocity-rpm pid.3.feedback
net pid-output-command pid.3.output spindle.0.speed-out
setp pid.3.Pgain [SPINDLE]P
setp pid.3.Igain [SPINDLE]I
setp pid.3.Dgain [SPINDLE]D
setp pid.3.bias [SPINDLE]BIAS
setp pid.3.FF0 [SPINDLE]FF0
setp pid.3.FF1 [SPINDLE]FF1
setp pid.3.FF2 [SPINDLE]FF2
setp pid.3.deadband [SPINDLE]DEADBAND
setp pid.3.maxoutput [SPINDLE]MAX_RPM
setp pid.3.maxerror [SPINDLE]MAX_ERROR
Jools
23 Nov 2019 12:15 - 23 Nov 2019 12:16 #151039
by jools
That didn't work so changed to this and linuxcnc loads now. Just need to hook the servo to the encoder input.
Does this look right?
Jools
# Spindle
net pid-output-command pid.3.output hm2_7i96.0.pwmgen.00.value
Jools
Last edit: 23 Nov 2019 12:16 by jools.
30 Nov 2019 16:11 #151581
by Leon82
Replied by Leon82 on topic 7i96 Configuration Tool
The io.hal file says if you make changes you are screwed.
How does one invert the io pin?
30 Nov 2019 16:29 #151583
Replied by PCW on topic 7i96 Configuration Tool
By changing
hm2_7i96.0.gpio.XXX.in
to
hm2_7i96.0.gpio.XXX.in_not
to
The following user(s) said Thank You: Leon82
30 Nov 2019 16:31 - 30 Nov 2019 16:36 #151584
by Leon82
Ah, the underscore got me
One of my axis is reversed. In not quite sure the best way to invert it
By changing
to
Last edit: 30 Nov 2019 16:36 by Leon82.
30 Nov 2019 16:47 - 30 Nov 2019 16:58 #151585
If you are in doubt about pin or parameter names you can run
halcmd show all > all.txt
(with linuxcnc running) to get a list of all parameters, pins and signals
There are many ways to reverse a step motor direction:
1. swap one motor winding
2. reverse the direction pin wiring (use DIR- instead of DIR+ for example)
3. invert the direction pin in hal ( setp hm2_7i96.0.stepgen.XX.direction.invert_output true )
4. invert the stepgen scale
Last edit: 30 Nov 2019 16:58 by PCW.
30 Nov 2019 16:57 - 30 Nov 2019 16:58 #151587
by Leon82
Thank you, I inverted the scale
hm2_7i95.0.stepgen.00.direction.invert_output
Last edit: 30 Nov 2019 16:58 by Leon82.
30 Nov 2019 18:35 #151594
by Leon82
When setting the external estop on input 0 I left the joint as select.
It is not tied to CNC however. Other hal files I have found had a couple extra lines under the estop section but I got a pin already defined error when I added them.
I've found some other Hal examples where an external estop was referenced but they were for a plasma machine
30 Nov 2019 18:45 #151596
You might take a look at Samco's Estop video:
forum.linuxcnc.org/24-hal-components/379...s-work-series#151551
Time to create page: 0.353 seconds
