7i96 Configuration Tool
10 Jun 2019 00:44 #136430 by persei8
Replied by persei8 on topic 7i96 Configuration Tool
I noticed that the ini file that the tool generates creates a line:
HALFILE = postgui.hal
whereas it should be:
POSTGUI_HALFILE = postgui.hal
Just sayin'
10 Jun 2019 13:02 #136466 by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool
Thanks, that has been fixed.
JT
26 Jun 2019 04:59 #137863 by pmconsulting
I'm getting there, BigJohnT. Just wanted to say thanks & keep up the hard but great work. I'll lend a hand as soon as I learn enough to be able to!
26 Jun 2019 05:13 #137864 by pmconsulting
Good advice, AgentWD40 - I wasted a day trying four different versions of Unix on this site: gnipsel.com/linuxcnc/uspace/index.html
Either those versions of Debian fail to recognize the USB as an installation device, or I get a startup error "unable to locate suitable memory target" when finally booting Linux Mint 19.1 after a ridiculously long compilation bummer.
I finally just went to linuxcnc.org & guessed. Those are pre-compiled, and they not only worked quickly, but it fixed a grub boot loader problem that had me locked out of Windows 10 on another drive.
My advice to anyone reading this is to download and install the LinuxCNC USpace 2.7.0 Debian 9 Streatch from linuxcnc.org/downloads, and then follow the instructions for adding the repos for updating to 2.8 at buildbot.linuxcnc.org.
I just wish someone would make a road map for all of this with fewer dead ends. The majority of what I tried on the gnispel.com website - although it looks really nice - was a disaster.
13 Jul 2019 16:51 #139262 by MakingStuff
Replied by MakingStuff on topic 7i96 Configuration Tool
I just want to say thanks for creating this tool. I used it today to setup my new 7i96 board and got the whole thing up and running in about 2 hours. I don't think I would have been able to do it in 2 days without this tool.
Thanks,
Bob
The following user(s) said Thank You: BigJohnT
20 Aug 2019 09:52 - 20 Aug 2019 13:42 #142569 by Clive S
Replied by Clive S on topic 7i96 Configuration Tool
Thanks for the config tool that I am trying for the first time But I am stuck here:-
3. Create a file in your home directory called .xsessionrc and add the following if your using Debian 9 then log out and back in or reboot the PC.
if [ -d $HOME/.local/bin ]; then
export PATH="$HOME/.local/bin:$PATH"
fi
Would you mind explaining how I do this?
Ie do I make a folder/directory or !!
Last edit: 20 Aug 2019 13:42 by Clive S.
20 Aug 2019 13:37 #142594 by tecno
Replied by tecno on topic 7i96 Configuration Tool
Does this configuration tool be setup to work with RPi4?
20 Aug 2019 14:03 - 20 Aug 2019 14:10 #142595 by persei8
Make sure you are in your home directory
cd
Check if you have a file called .xsessionrc (make sure to include the dot)
ls -als .xsessionrc
If not, then
sudo nano .xsessionrc
Then add the contents
fi
Then ctrl x, yes to save
Logout, login, good to go.
Last edit: 20 Aug 2019 14:10 by persei8. Reason: change ls -l to ls -als
20 Aug 2019 15:10 #142609 by Clive S
I have tried but failed. I move to the home dir that showed just the dir cnc and followed the instructions.
is this correct;-
The terminal was opened from the home dir. I logged out and back in. Then tried to run the config tool with 7i96 in a terminal is this correct.
20 Aug 2019 15:18 #142611 by BigJohnT
To see a hidden file (one that starts with a dot) you have to select show hidden files in the file manager.
JT
Moderators: PCWjmelson
Time to create page: 0.114 seconds
