Rebuilding a CHNC I Collet Closer
24 Mar 2010 21:20 - 24 Mar 2010 21:23 #2432
by BigJohnT
Rebuilding a CHNC I Collet Closer was created by BigJohnT
Once I figured out that all the O-Rings and Quad Rings were available from McMaster - Carr I was on my way.
Here it is all apart. The fun part was getting the bearing housing off without messing up the bearings. Take your time with it and it will come off. Oh, and close the collet first as if you leave it open and the rings seal at all it will have pressure when you try and take it apart.
Last edit: 24 Mar 2010 21:23 by BigJohnT.
24 Mar 2010 21:26 - 24 Mar 2010 21:26 #2433
by BigJohnT
Replied by BigJohnT on topic Re:Rebuilding a CHNC I Collet Closer
Last edit: 24 Mar 2010 21:26 by BigJohnT.
24 Mar 2010 21:28 - 24 Mar 2010 21:28 #2434
by BigJohnT
Last edit: 24 Mar 2010 21:28 by BigJohnT.
24 Mar 2010 21:29 - 24 Mar 2010 21:30 #2435
by BigJohnT
Last edit: 24 Mar 2010 21:30 by BigJohnT.
24 Mar 2010 21:31 - 24 Mar 2010 21:31 #2436
by BigJohnT
Last edit: 24 Mar 2010 21:31 by BigJohnT.
24 Mar 2010 21:33 - 24 Mar 2010 21:34 #2437
by BigJohnT
Last edit: 24 Mar 2010 21:34 by BigJohnT.
24 Mar 2010 21:35 - 24 Mar 2010 21:40 #2438
by BigJohnT
The worn part that I replaced from McMaster Carr. I have a lifetime supply of everything except the large Quad Rings.
- 2pcs 9452K18 AS568A - 016 O-Ring
- 2pcs1879T23 AS568A - 010 O-Ring
- 1pc 5308T233 AS568A - 166 O-Ring
- 2pcs 90025K617 AS568A - 261 Quad-Ring
- 1pcs 90025K388 AS568A - 227 Quad-Ring
- 1pcs 90025K464 AS568A - 229 Quad-Ring
Last edit: 24 Mar 2010 21:40 by BigJohnT.
22 Sep 2013 19:58 #39108
by gmouer
Replied by gmouer on topic Rebuilding a CHNC I Collet Closer
the pictures have disappeared from this thread. Any chance there is a copy of them around anywhere? Planning a mod to this collet closer and some pics would sure help.
23 Sep 2013 17:55 #39132
by BigJohnT
Replied by BigJohnT on topic Rebuilding a CHNC I Collet Closer
I wonder what happened to the photos... the edits look strange to me all withing a few minutes and not done by me.
I can't find the photos...
JT
JT
23 Sep 2013 18:52 #39135
by gmouer
Oh well, it was worth a shot to ask, just in case you had copys of the pics floating around. Thanks for looking into it.
Did you ever get the air leakage rate under control?
Moderators: cncbasher
