Re:Dahlgren Engraver Z axis air actuation
- bvandiepenbos
28 Feb 2011 04:20 #7502
by bvandiepenbos
Replied by bvandiepenbos on topic Re:Dahlgren Engraver Z axis air actuation
I like this idea, seems clever and workable... but I am not sure where to start since my knowledge of electronics is limited.
~*Brian
~*Brian
- bvandiepenbos
07 Mar 2011 23:51 #7621
by bvandiepenbos
here is my progress...
instead of trying to use the z-stepper output I hooked up C15 dual relay board from cnc4pc
using a breakout board.
pin 17 is relay for z-air solenoid
pin 14 is relay for turning on router motor
how do I turn on signal from EMC?
what gcode should I use?
~*Brian VanDiepenbos
08 Mar 2011 00:03 - 08 Mar 2011 00:04 #7622
by BigJohnT
Replied by BigJohnT on topic Re:Dahlgren Engraver Z axis air actuation
You could use the Z axis direction pin. Z down could be on Z up could be off.
So
G0 Z-0.5 ; on
G0 Z0.0 off
So
G0 Z-0.5 ; on
G0 Z0.0 off
Last edit: 08 Mar 2011 00:04 by BigJohnT.
- bvandiepenbos
08 Mar 2011 02:17 #7623
by bvandiepenbos
thanks John, I just tried it and it works turning a test LED on/off that I hooked to z direction pin 7.
But that same signal will not energized relay board??
could it be the signal is not enough power to trigger relay?
08 Mar 2011 10:48 #7630
by Rick G
Replied by Rick G on topic Re:Dahlgren Engraver Z axis air actuation
What are using for a power supply to the C15?
Are the LEDs on the board working?
It could be that the output of your parallel port is too weak, in which case a breakout board that boost the signal is in order or add a second parallel port with a higher output.
Rick G
Rick G
- bvandiepenbos
08 Mar 2011 13:01 #7632
by bvandiepenbos
hello Rick,
I am using wall-wart power supply. yes LED is lit.
You are right, I boosted signal to 5v with a powered breakout board, now it works.
Parallel port output measures 2.98v
it works!.... z-.1 =tool down, z0 =tool up
thanks guys.
thanks guys.
- bvandiepenbos
08 Mar 2011 13:04 #7633
by bvandiepenbos
now that my z-air up/down works I need to get relay #2 to turn on my router.
I am using pin 14
how should I activate it from g-code?
I am using pin 14
08 Mar 2011 13:07 #7634
by BigJohnT
You might want to put something in your hal to enable disable the output until you know the output direction is correct. You could put a PyVCP checkbox that enables the output after say you jog up or even better us motion to enable it with your first line a Z up. Play with it for a while to make sure you don't get some unexpected results.
08 Mar 2011 13:09 #7635
by BigJohnT
Well I just had one of those duh moments. Use the spindle output and use S1 M3 for on and M5 for off.
- bvandiepenbos
08 Mar 2011 19:44 #7656
by bvandiepenbos
ok, that sounds simpler.
what should I select in step config wizard for my pin 14 to work with M3?
thanks
thanks
Moderators: cncbasher
Time to create page: 0.092 seconds
