EMC Using MOTINC 100 Light
09 Aug 2011 20:58 #12355 by emad_ahmed2
i am using emc ver.2.4.3 and i have this error and i need help to solve this problem
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/emad/emc2/configs/motenc'
Machine configuration file is 'motenc.ini'
INIFILE=/home/emad/emc2/configs/motenc/motenc.ini
PARAMETER_FILE=motenc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=tkemc
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=4323
Cleanup done
Debug file information:
HAL: ERROR: function 'motenc.0.encoder-read' not found
motenc_motion.hal:9: addf failed
4323
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[343603.504376] I-pipe: Domain RTAI registered.
[343603.504386] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[343603.504390] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[343603.504397] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[343603.504400] PIPELINE layers:
[343603.504404] f0fcfe20 9ac15d93 RTAI 200
[343603.504407] c085cb20 0 Linux 100
[343603.532357] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[343603.532535] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[343603.532542] RTAI[sched]: hard timer type/freq = APIC/12469440(Hz); default timing: periodic; linear timed lists.
[343603.532546] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2992901000 hz.
[343603.532549] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[343603.532704] RTAI[usi]: enabled.
[343603.648187] RTAI[math]: loaded.
[343604.576919] RTAI[math]: unloaded.
[343604.658887] SCHED releases registered named ALIEN RTGLBH
[343604.673692] RTAI[malloc]: unloaded.
[343604.772029] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[343604.777409] I-pipe: Domain RTAI unregistered.
[343604.777421] RTAI[hal]: unmounted.
09 Aug 2011 21:44 #12356 by BigJohnT
Is the Montec a PCI card? If so it has to be installed or the config will fail to find the card.
09 Aug 2011 21:55 #12357 by emad_ahmed2
thank you for respond
yes it is motenc pci card and it is installed at add 0
so pleas tell me how to test it step by step
09 Aug 2011 21:59 #12358 by BigJohnT
I don't know anything about the Montec cards except where the manual is...
www.linuxcnc.org/docview/html/drivers_motenc.html
You might try loading the card from the terminal using HAL to see what errors it gives.
Open a terminal and type
halrun
loadrt hal_motenc
and see what that does...
09 Aug 2011 22:00 #12359 by BigJohnT
Also, you should get the latest version of EMC currently 2.4.6
09 Aug 2011 22:20 #12361 by emad_ahmed2
Now i have ver 2.4.6
and i test the
emad@emad-desktop:~$ halrun
halcmd: loadrt hal_motenc
halcmd: addf motenc.0.encoder-read servo-thread 1
<stdin>:2: addf failed
halcmd:
but as you see still have the same problem
09 Aug 2011 23:20 #12364 by BigJohnT
I assume you didn't create a servo thread before you tried to addf to it...
It does appear to load so that is a good thing
09 Aug 2011 23:21 #12365 by BigJohnT
You can use show pin to see what pins are present after you load the motinc driver.
10 Aug 2011 11:43 #12375 by andypugh
Interesting.
what do you get with:
halrun
loadrt hal_motenc
show funct
