Error trying to run first machine configuration
09 Sep 2012 18:01 #24097 by noqui
I have these error while trying to use emc2 for the first time. What should i do?
Diego from Argentina
Print file information
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMCS - 2.4.3
Machine configuration directory is "/home/pcnc/emc2/configs/3 axis CNC SABLE 2015"
Machine configuration file is "3 axis CNC SABLE 2015/3 axis CNC SABLE 2015.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCI0=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1545
Cleanup done
Debug file information:
Could not open command file "3"
1545
PID TTY STAT TIME COMMAND
Stopping realtime threads
unloading hal components
Kernel message information:
[ 2913.782101] I-pipe: Domain RTAI registered.
[ 2913.782118] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 2913.782123] RTAI[hal]: compiled with gcc version 4.4.3 (ubuntu 4.4.3-4ubuntu5)
[ 2913.782134] RTAI[hall]: mounted (IPIPE-NOTHREADS, INMEDIATE (INTERNAL IRQs DISPATCHE), ISOL_CPUS_MASK:0).
[ 2913.782138] PIPELINE layers:
[ 2913.782144] f8419e20 9ac15d93 RTAI 200
[ 2913.782148] c085cb20 0 Linux 100
[ 2913.838928] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 2913.839425] RTAI[sched] INMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 2913.839437] RTAI[sched]: hard timer type/freq = 250 (Hz), TimeBase freq = 1999728000 hz.
[ 2913.839448] RTAI[sched]: Linux setup = 999 ns, resched latency = 2943 ns.
[ 2913.844660] RTAI[usi]: enabled.
[ 2914.077799] RTAI[math]: loaded.
[ 2915.237791] RTAI[math]: unloaded.
[ 2915.425333] SCHED releases registered named ALIEN RTGLBH
[ 2915.444179] RTAI[malloc]: unloaded.
[ 2915.544032] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 2915.556381] I-pipe: Domain RTAI unregisterede.
[ 2915.556412] RTAI[hal]:unmounted.
09 Sep 2012 19:48 #24100 by cncbasher
your filename and directory structure has spaces in the filenames .. linux does not like spaces
09 Sep 2012 20:19 #24103 by noqui
Thanks a lot, problem solved!!
Time to create page: 0.053 seconds
