Accessing Forum
08 Jul 2019 15:44 #138870 by tommylight
Replied by tommylight on topic Accessing Forum
Windows ??? What is that ?!?!?!
Linux and Android, always, got only 2 timeouts to date, but the hangs are still present sometimes.
08 Jul 2019 20:52 #138892 by rodw
Replied by rodw on topic Accessing Forum
Is everyone using Windows (10) for the surfing and related problem?
Anyone having this problem surfing from Linux?
I am asking because my googling on this topic indicate a problem with Windows CryptSvc service.
This is not Windows related as the fault is also on my Chromebook....
08 Jul 2019 21:20 #138895 by tommylight
Been testing this all afternoon, and the results are still a bit fuzzy:
Got 2 more timeouts today
Ping to forum gets the reply in around 130ms always, even when hanging at TLS handshake
Got a page time of 0.68 seconds ( very well inside the norm, but much longer than usual for me )
Attached is the image of a terminal running ping to the forum while it timed out so the first 5 or 6 replies were while it was waiting.
Normally, given all the info we got till now, everything points to a bandwidth bottleneck, except Phill got a time of over 80 seconds and now i got nearly one, and that points to the server, but the info from JT clearly show the server is running fine.
Since i can not check the bandwidth, the only other thing that might be causing this is the CMS, will check this later
www.google.com/search?ei=NLIjXYGyJYLDmwW....gws-wiz.pZvSbiU8btI
08 Jul 2019 23:28 #138913 by phillc54
Replied by phillc54 on topic Accessing Forum
FWIW I use macOS
08 Jul 2019 23:41 #138916 by rodw
I am planning a visit around November for a month to see how far it really is. :silly:
Brisbane is a nice spot to add to your itinerary to catch up about LinuxCNC :)
09 Jul 2019 01:03 #138921 by Grotius
Replied by Grotius on topic Accessing Forum
Nothing is improved relating to forum speed.
IRC is even dramaticer. :whistle:
We couldn't connect to the server : Closing Link:
It's better to delete this text on the linux index/community page :
The other preferred way to contact us is on IRC, (#linuxcnc on irc.freenode.net). More information about connecting with your own client can be found on FreeNode’s how to use the network page.
09 Jul 2019 01:06 #138922 by phillc54
I have no trouble accessing either #linuxcnc or #linuxcnc-devel on IRC. I use the Kiwi web client.
09 Jul 2019 01:13 #138923 by Grotius
Hi Phil,
I can not login, only as user for a long time.. Over a year.
And as user you can say whatever you want. It's prohibited to say something.....
What i see as user is about 30 user's online. And i can login as their username if they are logged out without pass.
09 Jul 2019 01:16 #138924 by phillc54
You may need to register: freenode.net/kb/answer/registration
13 Jul 2019 07:33 #139239 by tecno
Replied by tecno on topic Accessing Forum
Now the forum is back again with *time out*, just wondering what causes these irritation stops.
Time to create page: 0.117 seconds
