Quickreference and KeyboardControl
17 Feb 2021 18:27 - 17 Feb 2021 18:27 #199167
by Jasper 3
Quickreference and KeyboardControl was created by Jasper 3
Hey,
I've got a question.
I want to control my CNC via my Keyboard. I'm using Linuxcnc 2.8 (Debian) but also had this problem under Linuxcnc 2.7....
The problem is that if I want to jog my actual selected axis. I can only jog in the negativ direction ( key " - "). The postiv direction does not work. In the Quickreference it should be key " = " but I also tried " + " and a lot of other key's. also when i set my keypadlayout to english it doesn't work.
I know that I can control my axis also with page up down and the arrowkeys or with the numpad. But thats not what I want.
Would be great if anyone can help me to solve this problem.
thank you very much for your help
greets
Jasper
greets
Jasper
Last edit: 17 Feb 2021 18:27 by Jasper 3.
18 Feb 2021 06:49 #199220
by aleksamc
Replied by aleksamc on topic Quickreference and KeyboardControl
What axes do you want to control (X,Y,Z, A, else)?
Does you want to control axes from PC keyboard?
Does your axes move correctly if you use software button from GUI?
What GUI do you use?
18 Feb 2021 09:19 #199229
by Jasper 3
Replied by Jasper 3 on topic Quickreference and KeyboardControl
Hey
I'm using Axis.
I want to control x,y or z. for example we can do it with the y axis.
yes i control the axis via my pc keyboard. but i dont want to use the Arrow keys or the Numpad.
Yes If i use the "-" and "+" button in Axis everything is fine.
thank you
greets jasper
I'm using Axis.
thank you
greets jasper
19 Feb 2021 08:49 #199380
Replied by Aciera on topic Quickreference and KeyboardControl
For Axis you can do a fair bit of customization by using .axisrc:
forum.linuxcnc.org/21-axis/14675-keyboar...nding?start=10#14703
26 Feb 2021 00:42 #200152
Replied by andypugh on topic Quickreference and KeyboardControl
Is there absolutely no chance of installing an MPG, physical buttons or even an XHC-type thing.
The keyboard is the worst of all the ways that we allow the system to be controlled. (There is a very real risk of missing a keyup, for example. Ever had a key stick and keep typing the same letter until you tap it again?)
Time to create page: 0.095 seconds
