New editor
- BeagleBrainz
- User is blocked
- Thank you received: 568
28 Jun 2021 03:16 #213084
by BeagleBrainz
New editor was created by BeagleBrainz
Maybe it's just me.
I'm having a issue when editing posts I quoted another user, and when there are code tags.
It want to quote the whole post, including the part I want to edit and puts all the end tags at the end.
If I don't make sense please ask me to explain it in a way you understand.
28 Jun 2021 03:38 #213088
by phillc54
Replied by phillc54 on topic New editor
+1
I am finding the same, it is very difficult using code tags.
28 Jun 2021 05:54 - 28 Jun 2021 06:01 #213092
by Clive S
Replied by Clive S on topic New editor
Forget the above I am talking blxMaybe it's just me.
Not sure if this is correct but it seems to work if you click on "Source" at the top left.
Last edit: 28 Jun 2021 06:01 by Clive S.
- snowgoer540
- Thank you received: 588
28 Jun 2021 11:51 #213123
by snowgoer540
Replied by snowgoer540 on topic New editor
+1, same. It's quite cumbersome, not sure how to get it to work right.
I also find the missing "preview" makes it difficult to play around and see what works.
I used "preview" quite a bit to make sure I didn't mess something up before I posted.
28 Jun 2021 12:17 #213126
by BigJohnT
Replied by BigJohnT on topic New editor
I usually just hit quick reply but after checking out the editor it's not working very well IMHO... quick look at Kunea configuration and I don't even see where the editor is... hmm looks like it's the bbcode that is messed up. Maybe the next update will fix that.
JT
JT
28 Jun 2021 12:24 - 28 Jun 2021 12:27 #213127
Replied by andypugh on topic New editor
I tend to type code tags by handTo edit, it seems that you can click the "source" button top left and then the tags are visible to edit.
Does that no longer work
For some reason?
Last edit: 28 Jun 2021 12:27 by andypugh.
- BeagleBrainz
- User is blocked
28 Jun 2021 13:07 #213130
by BeagleBrainz
Replied by BeagleBrainz on topic New editor
Edit that post Andy and all your closing tags with be bunched together one after the other at the end.
Yeah I hand code the tags as well
28 Jun 2021 13:16 #213134
It's a horrible bug, though.
Yes, I have noticed that. But you can at least move them back to where they belong if you edit the source via the button.Edit that post Andy and all your closing tags with be bunched together one after the other at the end.
28 Jun 2021 13:17 #213135
by arvidb
Hmm, no preview, and then if one tries to edit the post to fix any errors that messes the post up? That's not good! If it's not possible to fix this, is it possible to revert the forum to a more stable/working version?
Actually just unselecting the "Source" button moves all end tags to the end, so it's not even possible to preview the message that way.
Replied by arvidb on topic New editor
28 Jun 2021 13:23 #213136
And a well-reported one: github.com/Kunena/Kunena-Forum/issues
Time to create page: 0.179 seconds
