New editor
28 Jun 2021 13:53 #213139 by arvidb
Replied by arvidb on topic New editor
From github.com/Kunena/Kunena-Forum/issues/8166
So for any body for whom this is a blocking issue (me :S).
make a backup of ./media/kunena/core/js/ckeditor.js
then replace the contents of ckeditor.js with this one: raw.githubusercontent.com/Kunena/Kunena-.../core/js/ckeditor.js
This will revert the editor version back to 4.16.0 that doesn't have this issue.
Note this is a workaround and may re-introduce other issues solved in (custom) 4.16.1
28 Jun 2021 14:20 #213142 by BigJohnT
Replied by BigJohnT on topic New editor
Looks like preview was removed by the latest release.
www.kunena.org/forum/k-5-2-support-archi...eview-button-missing
JT
28 Jun 2021 14:47 - 28 Jun 2021 14:48 #213145 by snowgoer540
Replied by snowgoer540 on topic New editor
I suppose new is not always better haha.  Weird they got rid of preview.   The response in your link where the person said that it should preview as you type is unfortunately false.  I guess it would if I press source, and then click source again (it does, kinda, it still doesnt look exactly like the post comes out).
The update made mobile a bit cumbersome as well.
ignore this test for on the fly code insertion...
Last edit: 28 Jun 2021 14:48 by snowgoer540.
28 Jun 2021 15:09 #213150 by BigJohnT
Best thing to do with code is to click on the code button then paste the code between the tags.
test code here
next line
next line
16 Jul 2021 00:43 - 16 Jul 2021 01:17 #214961 by cakeslob
Replied by cakeslob on topic New editor
Is there anything that can be done about the right click menu? Im having a hard time using my browsers spell check with the new right click over taking the browsers right click.
edit, ok I see I can do it using the source button, but then it blocks out all the tag options
edit2, and then breaks all the tags
Last edit: 16 Jul 2021 01:17 by cakeslob.
16 Jul 2021 00:48 #214964 by tommylight
Replied by tommylight on topic New editor
Click on the "source", upper left side of the editor.
The following user(s) said Thank You: cakeslob
16 Jul 2021 12:45 #215043 by andypugh
Replied by andypugh on topic New editor
The new editor is a disaster. The only way that I have found to use it in source mode and hand-type the tags.
And that only works until you try to edit.
16 Jul 2021 12:54 #215047 by snowgoer540
I've tried hand typing the quotes and stuff as well, like I used to do in the old editor to break peoples walls of text apart and answer questions in order.  That doesnt work either.  It combines all of them into one large quote.
I miss broken email :(    :laugh:
16 Jul 2021 13:04 #215049 by tommylight
Took 4 tries to edit the "Linux Mint 19.3 install how to" ... :(
16 Jul 2021 13:36 #215053 by andypugh
Hand-typed tags works OK as long as you don't go back to the default view (for example, to see what it is going to look like)
But, I am not in a position to fix it.
