New editor
16 Jul 2021 22:57 #215104 by BigJohnT
Replied by BigJohnT on topic New editor
AFAIK there is no "fix" for the editor at this point. Kunena folks know there are problems.
JT
16 Jul 2021 23:10 #215106 by snowgoer540
Replied by snowgoer540 on topic New editor
One would reckon downgrading is out of the question? :laugh:
16 Jul 2021 23:30 #215108 by jepler
Replied by jepler on topic New editor
The issue filed with Kunena states that they are waiting for the ckeditor project to resolve the problem: github.com/Kunena/Kunena-Forum/issues/7873 -- I have inquired about where the ckeditor issue is filed, so I can track it too.
Sad to say, running old versions isn't tenable, because only the newest versions fix known security flaws. Making custom edits to the joomla, kunena, or ckeditor code doesn't work out well either, since every upgrade just overwrites them (and if there was a simple fix for this, I imagine they would have fixed it by now)
The upgrade this week-end won't make any net difference to this, as it is upgrading the OS and not the forum software itself.
I didn't see any place to switch/downgrade to an editor for raw bbedit with separate preview, either at a site level or a per-user level.
Sorry I don't have any good solutions :-/ If someone finds leads on the net about how to improve things, drop them in this thread. I'll try to monitor it for your ideas.
The following user(s) said Thank You: BigJohnT, phillc54, tommylight, Aciera, snowgoer540
17 Jul 2021 15:59 - 17 Jul 2021 16:00 #215142 by BigJohnT
Test code
Click on your avatar[code] and you can select one of three editors.
The first one I selected is somewhat broken... if you edit the message.
JT
[/code]
Last edit: 17 Jul 2021 16:00 by BigJohnT.
17 Jul 2021 16:02 - 17 Jul 2021 16:03 #215143 by BigJohnT
Well there are two editors you can select from but I'm not sure yet if selecting one makes any difference
Some test code here
JT
Yep doesn't seem to make any difference...
Last edit: 17 Jul 2021 16:03 by BigJohnT.
Time to create page: 0.106 seconds
