which motor and drives Mesa 7i96s
04 Dec 2022 20:38 #258526
by Nebra
which motor and drives Mesa 7i96s was created by Nebra
Hello everyone,
Im new to the subject. I have recently bought mesa 7i96s card and don't know what closed loop stepper driver model, and which motor to use with the card. I am interested into Stepper Driver Model: HBS57 and Stepper Motor model: 57HSE3N.
Can somebody please tell me if this is compatible?
(If not what to use for closed loop stepper motors that will work wit LinucCNC ?)
Thank you in advance!
- Thank you received: 5923
04 Dec 2022 20:45 #258527
Replied by tommylight on topic which motor and drives Mesa 7i96s
All stepper motor drives with "step/dir" control type will work with Mesa 7i96S, probably even the older "step up/step down" and "quadrature" ones will work with it.
Just to be sure, you are talking about closed loop steppers, meaning the loop is closed in the drives, right?
I am guessing from the models you mentioned, hence the above answer.
04 Dec 2022 20:56 #258532
by Nebra
Replied by Nebra on topic which motor and drives Mesa 7i96s
Well this is what i found for this driver model:
theese are the specification:
"Stepper Driver Model: HBS57
Maximum peak current: 5A
Impulse response frequency: 200KHz
Subdivision: 200~51200ppr
Voltage: DC16-70VDC
Pulse Signal: 3.3V/5V/24V compatible. No string resistor required
Protective function: overvoltage, overcurrent, tracking error out of tolerance
Signal input Compatible:5-24V signal (Don’t need a resistor)
Control Way: 32 bit DSP Vector Closed Loop
Advantage: Closed-loop vector control to ensure high-speed and high-torque output of the motor and no step to lose"
So I guess it is closed loop, but since my knowledge is minor I'm afarid to buy something that will not work. That´s why I need somebody to tell me if I buy this components with the card can I expect to be able to use it .
Thank you!
Voltage: DC16-70VDC
Thank you!
06 Dec 2022 01:01 #258647
Replied by andypugh on topic which motor and drives Mesa 7i96s
Anything that is step-dir controlled will work. And the ones you are listing are.
The following user(s) said Thank You: Nebra
06 Dec 2022 07:33 #258674
by Nebra
Thank you for the Info!
Time to create page: 0.165 seconds
