Z axis problem
03 Apr 2011 19:27 #8421 by malibu
Z axis problem was created by malibu
Keep getting error message that states "program exceeds machine maximum on axis Z" --how to I resolve this issue
03 Apr 2011 20:22 #8422 by BigJohnT
Replied by BigJohnT on topic Re:Z axis problem
Make your part shorter.
04 Apr 2011 10:20 #8451 by Rick G
Replied by Rick G on topic Re:Z axis problem
Is this a real part or just a simulation?
If you are running a simulation without a machine hooked up try jogging the z axis to a different position and then "touch off" there.
If you look at the AXIS screen you will see the dimensions of the part and a red box will include the dimension that is causing the problem so you will know which direction to jog to.
If it is a real part and you have properly homed, your axis limits are set properly and you have touched off in the proper location then it would seem the part is larger than your machine capacity.
Rick G
Time to create page: 0.071 seconds
