preguntas sobre 5axis bridgemill configuración
06 Aug 2020 00:33 #177447
by OT-CNC
Replied by OT-CNC on topic questions about 5axis bridgemill setup
JDS,
Did you get this worked out?
I'm about to embark on a rotating and tilting spindle 5 axis xyzbc srt gantry project. Where do I start with twin Y motors?
It looks like the xyzac−trt−kins are crossed out in the kins docs and 5axiskins − 5 Axis bridge mill is single Y.
I have been reading over the many docs and most seem to cover tilting table arrangements.
The last image with no further info is what I want to do, figure 11 except with YY, found in this doc:
linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html
Do I need to move to master branch (I'm on 2.8) ?
06 Aug 2020 00:51 #177451
by JDS
Replied by JDS on topic questions about 5axis bridgemill setup
Unfortunately no. We have moved since then and I haven't been able to finalize the project and test it out. I hope you get yours going and if so it would be awesome to hear about.
06 Aug 2020 01:52 #177454
by OT-CNC
JDS,
Thanks for the response. Will do.
I will need a bit more guidance from the experts...
06 Aug 2020 02:41 #177459
by JDS
I wish I could help more, but I am no expert lol. The folks on here can be pretty helpful. Try posting your questions on a new thread.
06 Aug 2020 09:26 #177482
As far as I know there are no important differences in this regard between 2.8 and master.
I am not clear what you mean about xyzac−trt−kins being crossed-out.
Try running the sample simulator config sim/axis/vismach/5axis/bridgemill which should be a lot like your machine.
That uses this kinematics:
github.com/LinuxCNC/linuxcnc/blob/master...nematics/5axiskins.c
Which does not, as it stands, support a double Y axis. But it is a very simple change to make it do so. (You just need to add an extra joint and, in the kins, make it take the same value as its twin)
Or, you could connect the Y axis motor command to two separate stepgens. But the modified kins is the better way.
Replied by andypugh on topic questions about 5axis bridgemill setup
06 Aug 2020 13:51 #177508
by OT-CNC
Hi Andy,
It was crossed out in this document (near the bottom):
linuxcnc.org/docs/2.8/html/man/man9/kins.9.html
I did play with the bridgemill sample. What is the W axis for? Docs refer to co linear. I can't jog it to see what it represents.
06 Aug 2020 14:18 #177509
Possibly a rendering error?
I don't understand the JW _joint_. The W _axis_ would be to allow easy jogging / movement along the tool axis for drilling operations.
- choqui2010
15 Aug 2020 19:53 #178320
by choqui2010
Replied by choqui2010 on topic questions about 5axis bridgemill setup
Hi Andy, sorry if this does not go into this topic but I have a little problem with the tool length compensation, the 5axiskins kinematics does not have an option where to add it to part of the pivot length.
please help
please help
15 Aug 2020 20:04 #178321
If you set up the tool table with the correct tool lengths (probably in the W column, so that the XYZ position is not compensated erroneously) then I think you could
The length would have to be the total offset of the tool-tip from the pivot point.
net pivot-length halui.tool.length−offset.w => 5axiskins.pivot-length
The following user(s) said Thank You: choqui2010
- choqui2010
16 Aug 2020 00:25 #178338
by choqui2010
thank you.
How can I contact you apart from this medium?
