Bob's Plasmac Build
25 May 2019 19:23 #134920
by bevins
Bob's Plasmac Build was created by bevins
- Thank you received: 5874
25 May 2019 21:24 #134930
Replied by tommylight on topic Bob's Plasmac Build
Hey Bev,
that is for the plasma you are building right ?
You should add some cross members to make the table more rigid in the middle as if cutting thicker steel plates it will buckle in the middle with time.
26 May 2019 06:46 - 26 May 2019 06:49 #134982
by pl7i92
Replied by pl7i92 on topic Bob's Plasmac Build
whow
it seams he plans on 2inch thick sheets
this may break the shop bottom if it is finished within that support
Will it be a Watertable or only airfree plasma
I hope you made Air Holes into the frame as the air is supposed to flow inside the bars
otherwise it will bend SOON and make it a unusable THC master pice
Last edit: 26 May 2019 06:49 by pl7i92.
26 May 2019 08:20 #134986
Replied by rodw on topic Bob's Plasmac Build
Looking good Bob.
26 May 2019 09:57 #134990
by bevins
Replied by bevins on topic Bob's Plasmac Build
Yeah I have some holes for air. And it will have a water table. Ac servos and Plasmac.........
I am using unistrut cross members. Support should be fine.If required I can add some.I did design triangular support but customer didnt want to pay for it.
- thefabricator03
- Thank you received: 531
26 May 2019 11:41 #134993
by thefabricator03
Replied by thefabricator03 on topic Bob's Plasmac Build
Looks Good,
It will be interesting to see how you are going to design the slat holders and the water tray. I take it that it will sit on top of the frame rather than sit in the frame.
30 May 2019 19:19 #135415
by bevins
30 May 2019 19:20 #135416
by bevins
Do I need a crossover Ethernet cable from computer to 7i92M?
30 May 2019 19:25 #135417
Replied by PCW on topic Bob's Plasmac Build
No, the 7I92 (and all of our Ethernet FPGA cards) support MDIX so will work equally well with crossover or straight through cables.
The following user(s) said Thank You: bevins
01 Jun 2019 12:20 - 01 Jun 2019 12:20 #135560
by bevins
Last edit: 01 Jun 2019 12:20 by bevins.
Time to create page: 0.242 seconds
