SOLVED - 6i25 Can't see swicthes change from test box
29 Sep 2022 11:37 #253024
by HansU
Replied by HansU on topic SOLVED - 6i25 Can't see swicthes change from test box
Can't you use an external pull down and disable the internal ones? But I guess you can only disable all internal pull ups and then you have to provide the other pull ups externally as well.
The following user(s) said Thank You: macsddau@linuxcnc
- macsddau@linuxcnc
- Topic Author
- Thank you received: 28
01 Oct 2022 06:11 #253147
by macsddau@linuxcnc
Replied by macsddau@linuxcnc on topic SOLVED - 6i25 Can't see swicthes change from test box
I don't see these lines in HAL :Aren't they required to get communication ?
addf hm2_5i25.0.read_gpio servo-thread
addf hm2_5i25.0.write_gpio servo-thread
- macsddau@linuxcnc
- Topic Author
01 Oct 2022 12:47 #253172
Not required. Tested, works withoutI don't see these lines in HAL :
addf hm2_5i25.0.read_gpio servo-thread addf hm2_5i25.0.write_gpio servo-thread Aren't they required to get communication ?
- macsddau@linuxcnc
- Topic Author
01 Oct 2022 13:11 #253174
- macsddau@linuxcnc
- Topic Author
01 Oct 2022 13:28 #253176
Mark as solved !
- Thank you received: 5874
01 Oct 2022 15:13 #253180
Replied by tommylight on topic SOLVED - 6i25 Can't see swicthes change from test box
Done, thank you.Mark as solved !
- macsddau@linuxcnc
- Topic Author
02 Oct 2022 07:09 #253225
Test box schematics :
Time to create page: 0.161 seconds
