Setting up PnCconf
03 Feb 2023 20:34 #263620
by imslo
Setting up PnCconf was created by imslo
I am putting together a MPCNC(Mostly printed cnc). I am ready to make my configuration. It would be much easier to do this program in metric because every thing about this machine is metric, Metric lead screw for z and metric pitch belts for x and y. My question is if I do this in metric will axis show metric information or will it show whatever is indicated in the gcode? I can barely get by in metric. I still have to convert everything to inches in my head. I don't want axis to show metric info,
04 Feb 2023 03:24 #263648
by Deckerjwd
Replied by Deckerjwd on topic Setting up PnCconf
if your running Axis(the default interface) you can pick what it displays under the view menu. i think the other interfaces have the option also but not sure
04 Feb 2023 03:47 #263649
by imslo
Replied by imslo on topic Setting up PnCconf
Thanks for the response I will try that.
Time to create page: 0.062 seconds
