Joining two motors
03 Aug 2020 11:19 #177028
by bevins
Replied by bevins on topic 2 motors on one axis
Since when does pncconf do dual motor gantries?
- Thank you received: 5907
03 Aug 2020 11:22 #177029
Replied by tommylight on topic 2 motors on one axis
Cant say for sure since i do not use it very often, but at least 6 months that i know of.
- Aldenflorio
- Topic Author
- Thank you received: 13
03 Aug 2020 14:11 - 03 Aug 2020 14:12 #177040
by Aldenflorio
Replied by Aldenflorio on topic 2 motors on one axis
I will be putting the limit switches on today. I see numbers, and I’ll have to post my config files in a couple hours. I’m not with my machine now
Last edit: 03 Aug 2020 14:12 by Aldenflorio.
03 Aug 2020 16:00 - 03 Aug 2020 16:01 #177051
by Clive S
Its the homing switches that are needed for dual axis but they can also be used as combined home and limit and then setup soft limits.
linuxcnc.org/docs/2.8/html/config/ini-homing.html
Replied by Clive S on topic 2 motors on one axis
Last edit: 03 Aug 2020 16:01 by Clive S.
03 Aug 2020 16:29 #177053
Replied by cmorley on topic 2 motors on one axis
A long time, though I havent got real world tested feedback much.
03 Aug 2020 16:31 #177055
It's still a configuration problem, as you should't be able to single joint jog a dual axis machine by default.
03 Aug 2020 16:44 #177056
No feedback = good !A long time, though I havent got real world tested feedback much.
- Aldenflorio
- Topic Author
10 Aug 2020 01:47 - 10 Aug 2020 01:48 #177786
by Aldenflorio
sorry for the late reply it took longer then i though it would. here are my configuration files. i think
Last edit: 10 Aug 2020 01:48 by Aldenflorio.
10 Aug 2020 06:59 #177795
In the ini file there are missing
HOME_SEQUENCE = -2
entries for all joints, -2 should be for both of the tandem joints while X and Z in your case should be 0 and 1 respectively.
In the hal file, delete the ....maxerror......=0.005 lines.
HOME_SEQUENCE = -2
10 Aug 2020 07:14 #177797
What version of linuxcnc are you using?
It seems there are two things I see that are not quite right in the INI:
KINEMATICS = trivkins coordinates=XYYZ kinstype=BOTH
This allows individual jogging of joints before homing.
drop the 'kinstype=BOTH' to disallow individual joint jogging (so the docs say)
also the there are no home sequence entries for the joints.
the Y and Y2 should have it so they jog together.
J0 HOME_SEQUENCE = 2
J1 HOME_SEQUENCE = -1
J2 HOME_SEQUENCE = -1
J3 HOME_SEQUENCE = 2
I think that would fix things (test carefully)
Time to create page: 0.108 seconds
