QtPyVCP Tutorial
07 Oct 2019 23:13 - 07 Oct 2019 23:14 #147384 by BigJohnT
Replied by BigJohnT on topic QtPyVCP Tutorial
Askjerry wrote:
I'll presume then that one must download the ISO from linuxcnc.org/downloads/ then perform an update procedure as there is no current ISO that can just be downloaded and run like the normal LinuxCNC install. Correct?
(I need to use the proper procedure if I make a YouTube tutorial video to push to my 3600 subscribers.) :-)
Thanks,
Jerry
You could download Debian 9 with LinuxCNC 2.7 and update to 2.8.
www.linuxcnc.org/testing-stretch-rtpreempt/
Or you could install Debian 9 or 10 (10 has a few issues with gscreen) from my instructions at gnipsel.com/linuxcnc/uspace/
JT
Last edit: 07 Oct 2019 23:14 by BigJohnT.
The following user(s) said Thank You: Askjerry
08 Oct 2019 01:51 #147405 by Askjerry
Replied by Askjerry on topic QtPyVCP Tutorial
I'm guessing the one to use is : www.linuxcnc.org/testing-stretch-rtpreem...uspace-amd64-r12.iso
And to update to 2.7... I believe... linuxcnc.org/docs/html/getting-started/updating-linuxcnc.html
So I have a plan... I'll do that as soon as possible.
Thanks BigJohnT !
Jerry
08 Oct 2019 07:28 #147436 by tommylight
Replied by tommylight on topic QtPyVCP Tutorial
There is also version r13 there, so use that, not r12.
Time to create page: 0.083 seconds
