qtpyvcp error vtk version Stretch
08 Jun 2019 08:56 - 08 Jun 2019 08:58 #136288
by pl7i92
qtpyvcp error vtk version Stretch was created by pl7i92
hi i am trying to get qtpyvcp to work
from gnipsels advice
pip install git+https://github.com/kcjengr/qtpyvcp.git
ERROR
Could not find a version that satisfies the requirement vtk (from qtpyvcp==0.2.3+303.g280371d) (from versions: )
No matching distribution found for vtk (from qtpyvcp==0.2.3+303.g280371d)
any advice i instaled the depencis
sudo apt install python-pyqt5 python-dbus.mainloop.pyqt5 python-pyqt5.qtopengl python-pyqt5.qsci python-pyqt5.qtmultimedia qml-module-qtquick-controls gstreamer1.0-plugins-bad libqt5multimedia5-plugins pyqt5-dev-tools python-dev python-setuptools python-pip git
There all NEW
Kernal
Linux cnc 4.9.0-8-rt-686-pae #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) i686 GNU/Linux
ERROR
There all NEW
Kernal
Last edit: 08 Jun 2019 08:58 by pl7i92.
22 Jun 2019 16:08 #137595
by pl7i92
Replied by pl7i92 on topic qtpyvcp error vtk version Stretch
cand solve this problem
wll install a new or plasmac version
20 Nov 2019 09:30 #150728
by Gnevko
Replied by Gnevko on topic qtpyvcp error vtk version Stretch
Hi people,
I have exactly the same problem now. I just followed the steps in the probe_basic instruction kcjengr.github.io/probe_basic/dev_install.html really from scratch (install Debian with Linux Cnc 2.7, upgrade to 2.8 and so on) .
At the moment I have only one idea why it doesn't work - I have phyton 2.7 and required is 3.* version.
20 Nov 2019 10:53 #150734
by Leon82
Replied by Leon82 on topic qtpyvcp error vtk version Stretch
I would install using these instructions first,
Then clone probe basic after.
qtpyvcp.kcjengr.com/install/installation.html
20 Nov 2019 18:09 #150775
by Gnevko
thank you for information!
but the result is the same:
pip install --editable .
Obtaining file:///home/cnc/qtpyvcp
Collecting docopt (from qtpyvcp==0.2.7+64.g24c3338)
Using cached https://files.pythonhosted.org/packages/a2/55/8f8cab2afd404cf578136ef2cc5dfb50baa1761b68c9da1fb1e4eed343c9/docopt-0.6.2.tar.gz
Collecting qtpy (from qtpyvcp==0.2.7+64.g24c3338)
Using cached https://files.pythonhosted.org/packages/cd/fd/9972948f02e967b691cc0ca1f26124826a3b88cb38f412a8b7935b8c3c72/QtPy-1.9.0-py2.py3-none-any.whl
Collecting pyudev (from qtpyvcp==0.2.7+64.g24c3338)
Using cached https://files.pythonhosted.org/packages/bc/a2/31a07829acea8e70a28c247f43fa5d981229ae0f9edfeddedf52de00709b/pyudev-0.21.0.tar.gz
Collecting psutil (from qtpyvcp==0.2.7+64.g24c3338)
Using cached https://files.pythonhosted.org/packages/03/9a/95c4b3d0424426e5fd94b5302ff74cea44d5d4f53466e1228ac8e73e14b4/psutil-5.6.5.tar.gz
Collecting HiYaPyCo (from qtpyvcp==0.2.7+64.g24c3338)
Using cached https://files.pythonhosted.org/packages/8c/1d/80ac5ac1d91eb3c6f7e7c14e3aacedefc5febb712a04977583e54747d414/HiYaPyCo-0.4.14-py2.py3-none-any.whl
Collecting pyopengl (from qtpyvcp==0.2.7+64.g24c3338)
Using cached https://files.pythonhosted.org/packages/9c/1d/4544708aaa89f26c97cc09450bb333a23724a320923e74d73e028b3560f9/PyOpenGL-3.1.0.tar.gz
Collecting vtk (from qtpyvcp==0.2.7+64.g24c3338)
Could not find a version that satisfies the requirement vtk (from qtpyvcp==0.2.7+64.g24c3338) (from versions: )
No matching distribution found for vtk (from qtpyvcp==0.2.7+64.g24c3338)
20 Nov 2019 18:30 - 20 Nov 2019 18:31 #150776
by Leon82
Try removing the period.
I may have had to do that. It's been a while
Last edit: 20 Nov 2019 18:31 by Leon82.
The following user(s) said Thank You: Gnevko
20 Nov 2019 18:41 #150778
by Gnevko
can I ask you to explain what do you mean with "Try removing the period."?
thank you in advance!
20 Nov 2019 19:25 #150783
by Leon82
--editable
--editable
20 Nov 2019 20:13 #150791
by Gnevko
the same
cnc@cnc:~/qtpyvcp$ pip install .
Processing /home/cnc/qtpyvcp
20 Nov 2019 20:41 #150793
by Leon82
Did you copy the sh file talked about twards the bottom? I believe I did that as well.
On Debian 9 (Stretch) ~/.local/bin/ is not on the PATH due to a regression in bash. This prevents being able to launch qtpyvcp from the command line or being able to use it as the [DISPLAY]DISPLAY directive in the LinuxCNC INI file. For a single shell session you can get around this by running export PATH=$PATH:~/.local/bin/ before launching linuxcnc or any qtpyvcp commands.
A more permanent solution is to copy the .xsessionrc file from the qtpyvcp/scripts directory into your home direcotry, then log out and log back in. This will add ~/.local/bin/ to your PATH each time xwindows starts. In the file manager select View > Show Hidden Files in order to see files that start with a dot like .xsessionrc.
