QTpyvcp Error: Sim will not open
27 Sep 2019 03:50 #146325 by billnixon
I am not able to open a sim with a qtpyvcp gui. I am following JT's instructions here:
Getting Started
Mint 19.2
LinuxCNC 2.8
4.19.1-rt3 #1 SMP PREEMPT RT
Here is what the error window says:
Qtvcp encountered an error. The following information may be useful in troubleshooting: LinuxCNC Version :2.8.0~pre1
QTvcp ERROR! Message #1
File "/usr/bin/qtvcp", line 480, in <module>
APP = QTVCP()
File "/usr/bin/qtvcp", line 318, in __init__
window.load_extension(opts.usermod)
File "/usr/lib/python2.7/dist-packages/qtvcp/qt_makegui.py", line 156, in load_extension
methods,self.handler_module,self.handler_instance = self._load_handlers([handlerpath], self.halcomp,self)
File "/usr/lib/python2.7/dist-packages/qtvcp/qt_makegui.py", line 184, in _load_handlers
mod = __import__(basename)
File "/usr/share/qtvcp/screens/qtaxis/qtaxis_handler.py", line 13, in <module>
from qtvcp.lib.toolbar_actions import ToolBarActions
File "/usr/lib/python2.7/dist-packages/qtvcp/lib/toolbar_actions.py", line 20, in <module>
from qtvcp.widgets.dialog_widget import LcncDialog as Dialog
File "/usr/lib/python2.7/dist-packages/qtvcp/widgets/dialog_widget.py", line 30, in <module>
from qtvcp.widgets.macro_widget import MacroTab
File "/usr/lib/python2.7/dist-packages/qtvcp/widgets/macro_widget.py", line 86, in <module>
class CustomSVG(QtSvg.QSvgWidget):
NameError: name 'QtSvg' is not defined
In the "LinuxCNC terminated with an error" window it asks if python-opencv and python-pyqt5.qtsvg are installed.
They are not listed with pip list. Could they be installed somewhere else?
Any help would be much appreciated. Thanks in advance.
27 Sep 2019 05:59 #146330 by cmorley
These errors are from qtvcp.
You mention pyqtvcp which is not the same project.
Which are you trying to use?
Chris
27 Sep 2019 11:55 - 27 Sep 2019 11:55 #146372 by billnixon
I'm sorry. I was loading the wrong sims. I meant to load a qtpyvcp sim. Probe basic does load.
Last edit: 27 Sep 2019 11:55 by billnixon.
27 Sep 2019 14:45 #146398 by pl7i92
its always a miss of the naming on this tow projekts that people are facing on a newcommer Base
it will be soon clear if you run more into the system
Time to create page: 0.082 seconds
