welche 24 Vsicherungen für die In und Outputs
- Mikron1207
27 May 2021 11:23 #210437
by Mikron1207
Drehenkoder anschliessen was created by Mikron1207
- Thank you received: 5909
27 May 2021 14:25 #210446
Replied by tommylight on topic Drehenkoder anschliessen
Ich denke ja ... aber wie das im hal geht weis ich nicht.
The following user(s) said Thank You: Mikron1207
- Mikron1207
27 May 2021 16:49 #210450
by Mikron1207
Replied by Mikron1207 on topic Drehenkoder anschliessen
ja mit der halk ist jetzt ein problem
27 May 2021 17:33 #210456
Es soll vie ein normaler encoder im hal sein, nur die nummer soll ander sein, encoder.00 stat encoder.0 oder encoder.1.
Hab kein 7i76 zur zeit, sorry.
27 May 2021 17:56 #210457
by RotarySMP
Replied by RotarySMP on topic Drehenkoder anschliessen
I have a normal jog encoder like that connected in my ENC.03 position on the Maho's 7i77. Works fine.Did you adjust the number of encoders in the loadrt HM2 line?
This is my HAL:
loadrt hm2_pci config=" num_encoders=6 num_pwmgens=0 num_stepgens=0 sserial_port_0=300xxx"
#PENDANT JOGGING
#---MPG
#Connect encoder 3 to jogging
net pen.enc.count <= hm2_5i25.0.encoder.03.count
net pen.enc.count => axis.0.jog-counts
net pen.enc.count => axis.1.jog-counts
net pen.enc.count => axis.2.jog-counts
#provision for future C axis
#net pen.enc.count => axis.4.jog-counts
#one pulse per four quadrature pulses
setp hm2_5i25.0.encoder.03.counter-mode true
#---MPG AXIS SELECT
net axis.X.sel hm2_5i25.0.7i77.0.0.input-01 => axis.0.jog-enable
net axis.Y.sel hm2_5i25.0.7i77.0.0.input-02 => axis.1.jog-enable
net axis.Z.sel hm2_5i25.0.7i77.0.0.input-11 => axis.2.jog-enable
#Provision for future C axis
#net axis.C.sel hm2_5i25.0.7i77.0.0.input-12 => axis.4.jog-enable
#---MPG INCREMENTS
#connect selectable mpg jog increments
# Increment C
net jog-incr-a <= hm2_5i25.0.7i77.0.0.input-03
# Increment X1
net jog-incr-b <= hm2_5i25.0.7i77.0.0.input-15
# Increment X10
net jog-incr-c <= hm2_5i25.0.7i77.0.0.input-10
# Increment X100
net jog-incr-d <= hm2_5i25.0.7i77.0.0.input-13
net jog-incr-a => jogincr.sel0
net jog-incr-b => jogincr.sel1
net jog-incr-c => jogincr.sel2
net jog-incr-d => jogincr.sel3
net selected-jog-incr <= jogincr.out-f
setp jogincr.debounce-time 0.200000
setp jogincr.use-graycode False
setp jogincr.suppress-no-input False
setp jogincr.in00 0000000
setp jogincr.in01 0.100
setp jogincr.in02 0.0100
setp jogincr.in03 0.001
net selected-jog-incr => axis.0.jog-scale
net selected-jog-incr => axis.1.jog-scale
net selected-jog-incr => axis.2.jog-scale
This is my HAL:
#PENDANT JOGGING
#---MPG
#---MPG AXIS SELECT
#---MPG INCREMENTS
# Increment C
# Increment X1
# Increment X10
# Increment X100
27 May 2021 18:17 #210459
Replied by Aciera on topic Drehenkoder anschliessen
zeig doch mal deine HAL
- Mikron1207
28 May 2021 18:03 #210546
by Mikron1207
Ich weiss nicht ob man es sehen kann,aber ich habs gelöst
- Mikron1207
29 May 2021 07:45 #210600
by Mikron1207
- Mikron1207
29 May 2021 07:53 #210601
by Mikron1207
Darf ich mit einem Voltmeter darauf rumstechen um V oder GND zu finden?
29 May 2021 08:45 #210606
by chris@cnc
Replied by chris@cnc on topic Drehenkoder anschliessen
