start up Help
05 Feb 2012 23:35 #17447
by paulocgcc
Replied by paulocgcc on topic Re:start up Help
Nope. No switch or other cable. Only for X Y and Z
I watched the signals in X Y and Z and is working.
parport.0.pin-12-in is yellow
06 Feb 2012 11:54 #17458
by Rick G
That shows EMC is working, however you really need to check if the signal is getting from your computer to your driver, for that you need a meter, scope or leds to test the connections at the driver.
A direction pin will go from around 5 volts in one direction and 0 in the other. If you see the say the X direction pin in hal change states there should also be a change in voltage at the driver.
Rick G
Replied by Rick G on topic Re:start up Help
Rick G
06 Feb 2012 14:34 #17463
by BigJohnT
Replied by BigJohnT on topic Re:start up Help
If Sherline tech thinks you have blown a fuse I'd put my money on him if you hot plugged it and they have big warnings about that...
12 Feb 2012 11:14 #17626
by Rick G
Any progress?
Rick G
Rick G
12 Feb 2012 20:17 #17631
by paulocgcc
Kind of..
Sherline Tech Help contact me. They are pretty sure that this a burned fuse... less for turning computer with driver box on, but due the fact that I swap cable axles with driver box on.
I have to find someone to change it once is soldered to the board, and I don't to risk it with my poor soldering skills. Due to work reasons I was able to do it until now. I think I will do it by Wednesday.
Anyway, as soon as I have it done I will let you all know.
Paulo
Paulo
15 Feb 2012 19:26 #17686
by paulocgcc
Dear All
Success!! Is alive and kicking....
The problems are the fuses in deed.
Lesson Took: Always read the "Caution" stickers...
Thanks for the group on helping me with that, hope from now on have "working" doubts...
15 Feb 2012 19:35 #17687
by BigJohnT
I love it when a plan comes together.
Glad to hear you got it up and running.
15 Feb 2012 21:39 #17691
Replied by andypugh on topic Re:start up Help
paulocgcc wrote:
Now you can start making swarf.
You might be surprised to know how pleased I am about that.Success!! Is alive and kicking.....
16 Feb 2012 10:52 #17713
by Rick G
Glad to hear you are up and running.
Now the fun begins!
Rick G
Now the fun begins!
Rick G
Time to create page: 0.215 seconds
