Configuration simoreg 6RB2030 siemens
John you would be so kind as to tell me how connected your (5i25) + (7i77) your servo siemens your Hardinge. have on your page (5i20) + (7i33) + (7i37).
and buy this kit (5i25) + (7i77), thank you very much for your wonderful collaboration at all
thanks
Jorge Viloria
I think I read in some thread, but you had 5i20, going to change 5i25, I thought I already did.
but I can ask what difference is there between (5i20) + (7i33ta) and (5i25) + (7i77) for the connection?
as I connect 7i77 to the inlet 14 and 56 siemens servo?
Best photo I can get as I can't open the door any more without moving the machine!
I'm currently installing a 5i25 - 7i77 in my BP knee mill...
I have a question I decided to buy (5i25) + (7i77) + (7i64).
by john experience as I have defined as connecting the servo to the card (7i77), now I have a doubt. with respect to the spindle motor.
my machine is equipped with a brand plus maxpak reliance.
The question I have is how to connect? if you can connect? as I can manage the direction of rotation. (M3 and M4). I have another card?
www.reliance.com/pdf/drives/instruction_manuals/D3867.pdf
thanks,
Jorge Viloria
so it should be possible to use a 7I77 analog output for speed control
I was checking the internet on my board I / O relay, Potter & Brumfield Relays.
is 2IO4B.
says in the manual:
relays.te.com/datasheets/2IO_DS.pdf
"Designed to Operate with Either neg. Or pos. True logic (active low or high) logic systems & different voltages. (Output modules only - must be input modules used in negative logic systems only.)"
The problem is that I do not have friends with the manual machine electrical and obia reason I can not turn on the machine to check voltage.
My question is this. can use negative or positive. currently noticed that all boards have four points connected together while leaving one cable to the other to place them in series.
That would be me saying they are negative?
what would be the best way to connect?
I can make an example of how it would be connected?
I think you might be able to use the 7i64 in place of those boards, though that would rather depend on what loads (voltage/current) are being switched.Friends thank God, I got the cards. "MESA" "5i25" + "7i77" + "7i64".
is 2IO4B.
When I recommended the 7i64 I was expecting it to be used for all the low-voltage switching of relays and suchlike.
I think that is saying that you can wire it any way you likesays in the manual:
Do you have, or can you make, a wiring diagram?My question is this. can use negative or positive. currently noticed that all boards have four points connected together while leaving one cable to the other to place them in series.
I do not understand, 7i64 can directly activate the solenoid? but the solenoid are at 120/240 VAC.
I swear I thought I 7i64 and complemented 2IO4B boards.
I have no machine electrical diagram. I turn to the devil.
Friend you explain me understanding that I am a beginner in this. Please
No, not at all. I was assuming 24V solenoids.
Definitely do not connect the 7i64 to AC voltages or any voltage > 50V.
Hopefully PCW can suggest the best way to connect the 7i64 to the relay board.
I don't really understand that data sheet, it is not at all obvious to me where the relays are, they don't seem to be shown.
