encoder_scale
24 Oct 2012 13:33 #25756
by jlviloria
encoder_scale was created by jlviloria
I have a concern.
My encoder has 2000 counts per revolution.
and my manual says this.
position feedback for the upper and lower Z axes is provided by their respective Z position encoders. these encoder send pulse signals to the control as their shafts are turned by Z motors.
One revolution of a Z motor and ballsrew equal one revolution of its encoder shaft, and equal 8mm of carriage travel in Z axis. During a single revolution of a encoder shaft.
my ENCODER_SCALE serious:
2000 count / rev x 1vuelta/8mm = 250cunt/mm
This would be correct?
thanks.
thanks.
24 Oct 2012 13:57 #25759
Replied by andypugh on topic Re:encoder_scale
jlviloria wrote:
Yes. However, it is possible that the encoders might be 2000 lines, and that would be 8000 counts so if you see an unexepcted 4x scaling error, that is why.
2000 count / rev x 1vuelta/8mm = 250count/mm.
The following user(s) said Thank You: jlviloria
24 Oct 2012 15:18 #25767
by jlviloria
Replied by jlviloria on topic Re:encoder_scale
Andy thanks,
Time to create page: 0.134 seconds
